Help with my build
Forum CPU & Components : Power Supplies, PC Cases & Case Mods - Help with my build
I am planning to build my first PC. I would like it to be useful for about 4 years, be quiet, and be able to play games such as WoW, Starcraft2, and Diablo 3, when the last two come out. Most of the time it will be used for simple web surfing and office software. I would like to dual boot Windows and Ubuntu Linux, so if anyone knows that I picked something not compatible, please chime in.
I was planning on the following, and would like the opinion of those who know more than me, which I expect is most people on this forum. Please let me know if my components are reasonable for my goals.
Case:
Antec p193 or p183. I'm curious if the side fan is worth it on the 193, or if I should stick with the smaller 183
http://www.newegg.com/Product/Prod [...] 6811129062
Power supply:
Antec CP-850 (850W). If I have the Antec case, may as well get the power supply that is cheaper for it.
http://www.newegg.com/Product/Prod [...] 6817371024
Motherboard:
Asus P5N-D
http://www.newegg.com/Product/Prod [...] 6813131232
CPU:
Intel Core2 Quad Q9400 2.66GHz
http://www.newegg.com/Product/Prod [...] 6819115131
RAM:
Kingston HyperX 4GB DDR2 800
http://www.newegg.com/Product/Prod [...] 6820104020
Hard Drive:
Western Digital Caviar Black 1TB (Is the Green edition too slow to be a primary drive?)
http://www.newegg.com/Product/Prod [...] 6822136284
Monitor:
ASUS VH226H Black 21.5"
http://www.newegg.com/Product/Prod [...] 6824236051
Optical Drive:
LG DVD/CD SATA drive (should I get the IDE version to save my SATA slots for other stuff?)
http://www.newegg.com/Product/Prod [...] 6827136153
Video Card:
ASUS GeForce GTS 250 1GB Dark Kinght
http://www.newegg.com/Product/Prod [...] 6814121309
CPU Cooler:
Noctua NH-C12P (Do I need a CPU cooler that isn't the stock one? Is this significantly more quiet?)
http://www.newegg.com/Product/Prod [...] 6835608001
Thanks in advance for you help, I could really use it.
Steve
Message edited by sschnee on 05-16-2009 at 03:00:11 AM
Sponsored Links
So far things look pretty good, heres a few things I found.
You should pick up a different mobo other than the 750i. If you plan to run SLI, you can get it, but I would recommend a 780i at least. If no SLI, pick up a P45 or x48 board.
Depending on if you plan to OC or not, a 3rd party cooler is recommended. The stock one works, but it really is terrible when you see the temps that it allows the CPU to run at. For long term gaming, you should probably get one.
Reply to Abydosone
- 0 +
I appreciate your advice, but I don't think I fully understand it. What are the differences between those northbridge chipsets that would make me pick one over another?
Also, I don't plan on doing SLI for now, but I might in the future, so I should get a mobo that supports it, right?
Reply to sschnee
Forget about the C2Q and go straight to this I7 setup. Spend the extra 130 dollars for this.
http://www.newegg.com/Product/Prod [...] 6813186170
http://www.newegg.com/Product/Prod [...] 6819115202
------------------------------ Core I7 920 D0 @ 4.2Ghz
MSI X58 Pro-E
32GB SSD, WD Blacks In R0
Sapphire HD 5870's In XFire
Reply to PsychoSaysDie
- 0 +
In case I do want to SLI in the future, how about this MoBo?
Asuss P5N-T
http://www.newegg.com/Product/Prod [...] 6813131231
Also, I want to go for quiet computing, so I think I'll pick the WD Caviar Blue 640 GB HD since it is suppodely quieter than the 1 TB Caviar Black I had chosen previously.
http://www.newegg.com/Product/Prod [...] 6822136218
Finally, I think the Antec P193 case is too much case for me, and the P183 is better suited:
http://www.newegg.com/Product/Prod [...] 6811129061
I would still like more advice from everyone.
Thanks,
Steve
Reply to sschnee
- 0 +
musicmanivi wrote :
what is your max budget?
As it stands, my build is around $1350 from newegg. I could go as high as I need to to meet my goals of:
1) Quiet - my current PC sounds like a jet engine, and it's driving me crazy.
2) Powerful enough for Starcraft2 when it comes out
3) Still be useful in 4 years for medium gaming, not FPS shooters.
So I could spend a few hundred more if I needed to, but I don't want to waste money either.
Reply to sschnee
- 0 +
Have you looked at an AM3 Build?
ASUS M4A79T Deluxe AM3 DDR3 AMD 790FX ATX AMD Motherboard & OCZ Reaper HPC 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Dual Channel Kit Desktop Memory Model OCZ3RPR16004GK - Combo Deal ($259.98)
http://www.newegg.com/Product/Comb [...] mbo.193392
AMD Phenom II X4 955 Black Edition Deneb 3.2GHz Socket AM3 125W Quad-Core Processor Model HDZ955FBGIBOX - Retail ($245.00)
http://www.newegg.com/Product/Prod [...] 6819103674
Antec P183 Black Aluminum / Steel / Plastic ATX Mid Tower Computer Case & Antec Signature SG850 850W Continuous Power ATX12V / EPS12V SLI Certified CrossFire Ready 80 PLUS BRONZE Certified Modular ... - Combo Deal ($342.98)
http://www.newegg.com/Product/Comb [...] mbo.194005
Noctua NH-C12P 120mm SSO CPU Cooler - Retail ($64.99)
HIS Hightech H485QS1GP Radeon HD 4850 1GB 256-bit GDDR3 PCI Express 2.0 x16 HDCP Ready CrossFire Supported IceQ4 Video Card - Retail ($150.00)
http://www.newegg.com/Product/Prod [...] 6814161245
Western Digital Caviar Black WD6401AALS 640GB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive - OEM ($74.99)
http://www.newegg.com/Product/Prod [...] 6822136319
LG 22X DVD±R DVD Burner with LightScribe Black SATA Model GH22LS30 - OEM ($23.99)
ASUS VH226H Black 21.5" 2ms(GTG) HDMI Widescreen LCD Monitor - Retail ($179.99)
Total Cost: $1,361.91 (Not including Shipping & MIR)
I would suggest going with either an AM3 build or Core i7 920 build if you are wanting to keep the system for 4 years. Either one of those processors will have more staying power than the Core2 Quad. Also, the only upgrade you would need to make if you run into gaming problems is upgrade your GPU or add a 2nd GPU in Crossfire/SLI depending on what route you take.
------------------------------ Recommended Builds by Usage
Step-by-Step Guide to Building a PC
Reply to tecmo34
^ except drop the am3 mobo and ddr3 ram for an am2+ one and ddr2 ram, am3 isn't worth it since it will be obselete in a year anyway.
Reply to Helloworld_98
- 0 +
Tecmo,
Not to be difficult, but if I could stick with Nvidia, I would like to. My understanding is that they are better supported in Linux, which would be my primary OS when not gaming. Is that no longer the case?
Also, I have never had a PC with a AMD processor. Are those just as well supported as Intel when it comes to Linux (Ubuntu)?
Reply to sschnee
- 0 +
Nvidia is the better choice I would agree. Since you are set on Nvidia, the Core i7 is your best bet. Nvidia 7xx boards have to many reported problems. I've experienced it myself when my old MSI P7N SLI Platinum fried and took my Q6600 with it.
New Build:
Intel Core i7 920 Nehalem 2.66GHz LGA 1366 130W Quad-Core Processor Model BX80601920 - Retail ($279.99)
GIGABYTE GA-EX58-UD3R LGA 1366 Intel X58 ATX Intel Motherboard - Retail ($199.99)
http://www.newegg.com/Product/Prod [...] 6813128375
OCZ Platinum 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Triple Channel Kit Desktop Memory Model OCZ3P1600LV6GK - Retail ($99.99)
http://www.newegg.com/Product/Prod [...] 6820227381
ASUS GeForce GTS 250 1GB Dark Kinght ($149.99)
Total Cost: $1,416.90 (Not including Shipping & MIR)
Difference between your original build + $66.90. This price difference is well worth the extra money, IMO.
Reply to tecmo34
Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > Help with my build
There are 1236 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
