Tom's Hardware > Forum > CPU & Components > Other Components > Burn Problem DVD-R Vista
Forum CPU & Components : Other Components - Burn Problem DVD-R Vista
Pioneeer DVR_213LS
Unable to burn with Nero 8.3.13.0, also tried using Windows Vista burn. Unable to write to DVD-R was able to write to CDR.
Had no troubles with the DVD-R disc a week or two back
With Windows burning software is comes up with unable to format. I cannot remember what Nero said but it starts to burn and then comes up with message.
I do not know if the lattest update with Vista does it.
I made certain I had the lattest firmware for the Pioneeer DVR_213LS just to see if firmware would fix it
S213NP_V101(20080129)_for_213LS to try elimate problem
I did find restoring it before the update I was able to write to DVD-R. Updating again I find I cannot write to disc again
I did find that DVD+R one can write to.
Sponsored Links
Dont use that update!
Reply to daship
There are 1113 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
