Tom's Hardware > Forum > Homebuilt Systems > General Homebuilt > Troubleshooting random system power-downs.
Forum Homebuilt Systems : General Homebuilt - Troubleshooting random system power-downs.
Hi, Everyone,
I've been trying to troubleshoot an intermittent problem for the last couple of months, and since the system was built from parts mostly recommended on Tom's Hardware, I'm hoping someone here might be able to help.
The original setup was:
CPU: an Intel Q6600 G0 CPU
MB: MSI P6N SLI Platinum motherboard
PSU: Aerocool ZERODBA-S620
RAM: 2x1GB of Patriot RAM (PDC22G6400LLK)
Graphics: EVGA 8800GT 512 MB
HD: 500GB WD5000ABYS
DVD: Sony/NEC AD-7170S-0B
The system ran very stable for about a year. It would then intermittently power-down instantly. The screen would go black, fans shut off, but the motherboard still has power (on-board LAN card lights still flash, etc). Hitting power button would start it up again, but quite frequently it wouldn't even make it to boot screen before powering down again. This is still my biggest problem that keeps on recurring. It doesn't seem to be related to heavy loads--it often happens at idle. It will sometimes go for hours without shutting down, sometimes it'll go down within 5 minutes of being turned on.
Memtest gave me an error at the same address every time I ran it. I tried setting DRAM options to 4-4-4-12, even 5-5-5-15 to no avail. Running system on only one stick of RAM seemed to greatly reduce the frequency of the problem, but replacing both sticks of RAM didn't resolve the issue.
I've updated the MB BIOS to 1.7, which also didn't resolve the issue.
I've recently installed a couple of tools to look at temperatures and voltages. One thing I noticed was that "vcore' would fluctuate from 1.14 to 1.34.
Any advice on what to look at next to make this machine stable again? Any help and suggestions much appreciated!!
Thanks,
Dodgy.
Sponsored Links
If you are getting errors in memtest at stock, you need to replace the memory sticks or motherboard. Sounds like the motherboard is the problem.
it's normal for vCore to fluctuate.
Your power supply is a Tier 4, not recommended. I suggest you get a good one.
http://www.xtremesystems.org/forum [...] p?t=108088
500W to 550W: 12 Power Supplies Compared - Anandtech.com
http://www.anandtech.com/casecooli [...] =3516&p=35
------------------------------ Google is your friend and Bob's your uncle
Reply to evongugg
Ya, i'm wondering if the cause of this is the PSU taking out componenets. So many people overlook the value in having a good quality PSU until its to late :( The PSU that you have is not rated very well.
What are the tempatures your getting?
Are you getting any sort of bios beep codes when starting your computer?
Also try running scan disk and defragment.
Message edited by kubes on 02-26-2009 at 03:08:47 PM
Reply to kubes
Thanks for the belated posts, guys. I actually went with the aerocool unit because it was originally recommended on Tom's Hardware!
Thanks to advice in another forum, I replaced the PSU with a PC Power & Cooling unit and my problems seemed to have disappeared (knock on wood!).
Thanks again,
Dodgy.
Reply to dodgy
There are 832 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
