Archived from groups: microsoft.public.pocketpc.multimedia (More info?)
I have a ASUS MyPAL 620BT PocketPC with Windows PPC 2003. If i try to
stream an audio stream over bluetooth, it hangs every few seconds. even
a 40 kbit/s stream hangs. I have installed a cpu monitor to see if the
cpu has not enough power. but the performance of the cpu is not the
problem. if i copy a file via Obex ftp the transfer rate is about 300
kbit/s. this should be normaly enough for audio streams. maybe somone
had the same problem and has found a solution.
CG [Mon, 04 Oct 2004 19:40:39 +0200]:
> via Obex ftp the transfer rate is about 300 >kbit/s.
A solution was found a long, long time ago. See sig/read FAQ.
40th Floor - Software @ http://40th.com/ iPlay : the ultimate audio player for iPAQs
mp3, ogg, mp4, m4a, aac, wav, play & record
parametric eq, xfeed, reverb - all on a ppc
