Should I get a new power supply?
Last response: in Components
I plan on upgrading from my old Pentium 3.2Ghz(prescott) to a Core 2 Quad( 8200, 8400 or a 9400 are my choices)
So I'm only upgrading CPU, MOBOand RAM....its just a budget upgrade.
My current power supply is an enermax 535W FMA model, which I got last summer to replace an older 460W power supply(also enermax) because I needed the PCI-E connector to power the Geforce 9600 card I got.
Anyways, I'm wondering if I need to replace the power supply as well for the new setup system? Or is this one sufficient for the new system? The power supply has 2 +12v rails(18A).
Thanks
More about : power supply
Ask the community
