Memory problems
Forum Motherboards & Memory : Elitegroup - Memory problems
i have windows vista ultimate, i get alot problems extracting large files, and vista memory diag says i have a hardware problem, what i would like to know is if its just the ram or a problem with d board, bcuz i read in the booklet for mt board that it only supports unbuffered ram but the ram i have in it is buffered, is that the problem?
Sponsored Links
Running buffered memory usually will not cause any problems, other than it will be slower than unbuffered memory. But you never know, after all you have hardware plugged into the board that it does not support.
A complete list of your build would be helpful.
Reply to jitpublisher
- 0 +
amd dual core 5200+ 2.7 ghz
ECS GeForce7050M
3gig markvison ddr 2 800 ram
wd 500 gb hard drive
his radeon hd 4670 1gb
Reply to nate_09
- 0 +
ECS GeForce7050M
Reply to nate_09
Tom's Hardware > Forum > Motherboards & Memory > Elitegroup > Memory problems
There are 523 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 meywd won the Freshman badge
  • 01:00 nayega won the Freshman badge
  • 01:00 gpfear won the Freshman badge
  • 01:00 Conrad925 won the Freshman badge
  • 01:00 skythra won the Freshman badge
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
  • 01:00 patlabor44 won the Uniformed badge
  • 01:00 Kiren won the Uniformed badge
