Tom's Hardware > Forum > Graphic & Displays > Nvidia > [Monitor] Not sure if this belongs here, but I need some help.
Forum Graphic & Displays : Nvidia - [Monitor] Not sure if this belongs here, but I need some help.
I don't know much about monitors, but what I do know is I need an upgrade. I have a BenQ FP91G+ monitors that is like 6 years old. I deffinatly want a size upgrade, latency upgrade, widescreen, and resolution upgrade. I mainly play video games, but I don't have the lights on so I don't think a glossy screen would be bad. I also don't want to spend more then 300 dollars. I'm looking at this, but I'm not sure if its good.
http://www.newegg.com/Product/Prod [...] 6824009125
Reviews seem good, but a lot of bleeding comments. So I'm not sure. I was looking at the Samsung T220 (or what ever those are), but I want a higher max resolution then they have.
Thanks :D
Sponsored Links
You cant go wrong with that monitor. I have the 22" version I picked up for like $159.
------------------------------ P965/Q6700@3.2 8MB HD4850 OC Edition
4GB Corsair XMS 800
Vista64/Win7
Fatality 550w/Antec 300
Reply to zipzoomflyhigh
- 0 +
i have the samsung T240. basically the same thing but bigger. it's an excellent monitor, as long as you won't be using it with a game console. there's no way to preserve the 16:9 aspect ratio. it'll always be stretched to 16:10, which does have a noticable vertical streching effect.
------------------------------ ECS A780GM-A, Phenom II x3 710, 4GB Corsair @800Mhz, HIS Radeon 4850, Seagate 7200.11 500GB, Auzentech X-Plosion 7.1 Cinema, LiteOn DL-DVD w/Lightscribe, ASUS TA-863, OCZ StealthXStream 500W, Samsung Syncmaster T240, Windows 7 Ultimate x64
Reply to Nik_I
- 0 +
My 2 cents: you are aware of the performance hit that games can sustain from higher resolution, right? Going from a 1280x1024 monitor to a 1920x1200 can mean the difference between a 100-150$ video card and a 200-300$ video card.
------------------------------ The capacity to learn is a gift; The ability to learn is a skill; The willingness to learn is a choice. - Rebec of Ginaz
http://valid.canardpc.com/cache/banner/600609.png
Reply to Zenthar
I have a GTX280. I think that should be enough to handle that resolution.
Message edited by Helltech on 03-14-2009 at 08:01:20 PM
Reply to Helltech
No all my consoles are hooked up to my TV. At any rate, will there be a lot streching with this one and pc games?
Message edited by Helltech on 03-14-2009 at 08:00:29 PM
Reply to Helltech
- 0 +
I can't speak for other games but COD4 and COD5 both look amazing...I have the Samsung 2493HM, which is like the 240T and those two games do not stretch they scale really well keeping the game looking natural....At least to my old eyes. Oh and I have the GTX 295 if that matters.
Reply to jack64
Yea... well I don't plan on using it for anything but PC games, so I don't think there will be much streching.
Reply to Helltech
- 0 +
Some older games have problems with that resoloution, in some cases that can be corrected by altering the games configuration files or patching.
Just one point on the monitor, it`s TN and 6 bit colour, you might want to try and see it working, particularly if you plan on watching movies on it .
Reply to coozie7
http://www.newegg.com/product/prod [...] 6824014090
Well this is what I have, and movies look great on it to me. It it 6-bit also.
Reply to Helltech
There are 585 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
