I just finished a build and I'm realizing that I have a serious heat problem within my case.
First aspect of the problem are the cooling of the video cards. The cards that I bought do not have the best cooling stock cooling solution, (Palit 1 gb sonic edition 460 gtx (non platimum)), as they do not come with heatsinks over their vram. Updating to the recommended new bios distributed by Palit did not solve heating problem.
I'm running two of them on an asus premium p6x58d board, (which the two x16 pci slots are the top two, and the bottom one runs in x8 only if there are three cards inserted, otherwise only x1). Therefore, there is not a lot of space between the cards (if at all), causing the top card to run much hotter than the bottom one. As mentioned, trying to load the second video card in the bottom port leads to drastic performance drops. Loading the video cards with Kombuster leads to temperatures in the high 90's Celsius. Extended run without cancelling the problem can cause the top video card to reach failing temperature (which is 104 degrees Celsius).
I have limited experience with after market coolers, but I'm pretty sure I'm in dire need of an alternate solution than the stock cooling solutions provided. I would also like any information on how to increase the distance between the two cards. It surprises me that the premium board that boasts SLI leaves such little space between cards that take up dual slots on their own. However, that's probably more due to my niavette rather than product quality.
I'm not quite sure what more information is required that's relevant to heat, but the case is an antec 300. I have both of the case fans on high. I have cooler master v8 cooler on the cpu
