Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > Supermicro psu and gigabyte motherboard problem
Forum CPU & Components : Power Supplies, PC Cases & Case Mods - Supermicro psu and gigabyte motherboard problem
Hi there,
I have a supermicro chassis and redundant power supply, along with a Gigabyte GA-EX58-UD4P mother board, and an i7 920 CPU.
When I go to boot the computer all i get are sort beep which keep going.
Tried powering up with another psu and no beeping.
I did a little more reasearch and started metering the psu outputs. I found that both were identical except that the super micro did not have a -5v line, jsut an empty whole.
Does someone on here have a better idea as to what the deal is with the -5 line? looking at Wikipedia, they suggested that the -5v line is no longer used and is optional....
turns Supermicro motherboards do not require -5v....
Do I have any other options other than going with a supermicro board?
thanks,
-Erik
Sponsored Links
What PSU are you using? How many amps does it have on the 12V rail(s)? What are the rest of your specs?
------------------------------ *How To Ask For New Build Advice*
HAF 922 | HX750
Rampage2Gene | i7 920 D0 | 6GB Gold 1600 | Hyper 212+
Caviar Black 640GB | HD3870
Reply to theAnimal
- 0 +
The ATX 2.0 specifications did away with the -5 volt output.
Reply to jsc
There are 1068 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
