Hey Everyone!
I was wandering, I am looking to upgrade to water cooling, but my case is WAY to small, I am on a budget of about £180 and I was wandering if I should buy a Thermaltake Kandalf L.C.S
or buy all the components myself.
Cheers
r0$$Y
Sponsored Links
What's current case? I don't think you need such a big case to accommodate, but I could be wrong. In any case, you can consider the [url=http://www.newegg.com/Product/Product.aspx?Item=N82E16811129021]Antec 900[/iurl].
------------------------------ Desktop | E7300 | P5KPL-AM | 2GB DDR2 667MHz | NVIDIA 9500 GT | ST3320613AS | w2228h
XPS M1330 | T8300 | Dell 0U8042 | 2GB DDR2 800MHz | NVIDIA 8400M GS | WD2500BEVS-75US | 1280 x 800
Reply to r_manic
you can fit a radiator anywhere as long as you have a dremel. Definately build the loop yourself. Thermaltake water cooling is garbage from what I hear. The coolermaster S and the haf are nice cases for water cooling if your still set on replacing the case.
Reply to PsyKhiqZero
Please post a link or two to vendors in your country so we can look and see what is available.
Reply to JohnnyLucky
DO NOT spend money on water cooling kits. With the exception of a few kits like the Swiftech Apex, the kits are not good. I recommend you upgrade the case first and then spend money on a real water cooling system. If you don't have the money to do all of it at once do it in stages. Get case first then the pump,then the block and so on.You are very likely to be disappointed by the performance of the Thermaltake,etc kits.
Also have you considered placing the rad outside the case with a rad box? The pump,res,tubing,block don't take up too much space in a decently sized case.
Message edited by Shadow703793 on 05-19-2009 at 03:13:25 PM
------------------------------ http://farm3.static.flickr.com/2617/3815217176_0a5be7955d_o.gif
http://farm4.static.flickr.com/3553/3818083596_1a772f7162_o.gif
Reply to Shadow703793
It's weird though because I already have a demon case in the antec 900 but it's way too small for Water Cooling from what I hear, I was thinking of the Chieftec Aegis
Reply to xtream_ocer_intel_nvidia
also i have:
Q6600 w/G0 stepping @ 3.6GHz
Asus P5N-D
Zotac 9800GT synergy edition
4GB ram
and a 750W PSU
And I'm in England....soo
Scan.co.uk
Dabs.com
Thermaltake water kits suck!!!!
Reply to xtc28
Cheers, thanks for that. Any ideas on what kit I could get??
------------------------------ The Meaning Of Life
Sometimes it's a chicken,
Sometimes it's a chair,
Sometimes its a piece of cheese suspended in the air
Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > Water Cooling Help!
There are 1288 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
