Water Cooling Crisis!
Forum CPU & Components : Power Supplies, PC Cases & Case Mods - Water Cooling Crisis!
Hey Everyone!
I was wandering, I am looking to upgrade to water cooling, but my case is WAY to small, I am on a budget of about £180 and I was wandering if I should buy a Thermaltake Kandalf L.C.S
or buy all the components myself.
Cheers
r0$$Y
Sponsored Links
thermaltake LCS system's are poor, and for the less you can get a Chieftec Aegis with the custom water cooling system by alphacool, all you need is the coolant and you have a complete water cooling system for the CPU.
but you can only buy them on scan.co.uk.
Reply to Helloworld_98
Don't buy any water cooling kits. Period. There are a few Swiftech kits that are the exception here, but most after market LCS are cr@p.
------------------------------ http://farm3.static.flickr.com/2617/3815217176_0a5be7955d_o.gif
http://farm4.static.flickr.com/3553/3818083596_1a772f7162_o.gif
Reply to Shadow703793
The Swiftech H20-H220 is a very nice watercooling kit. Hell I would go as far as to say it is the best watercooling kit out there and the only one worth buying.
Reply to The_Blood_Raven
I want a BIG loop with a VGA block, Res and Pump, it's mostly for show =D, and because I said that you're probably going to say 'well you don't need it' but I do ^^
Reply to xtream_ocer_intel_nvidia
look at the zalman reserator series, you'll also need to get some vram sinks aswell.
I think the non-fan one just about fits in your budget.
Im not worried about ram i mostely want VGA and CPU cooling
^ I meant heatsinks, the ram can die if it gets too hot aswell you know.
^ nope, the vram doesn't, the one on your graphics card, that's why you need heatsink's or something that covers both the GPU and ram.
Good luck finding a kit that will cool your GPU AND CPU.
what about this one? I was browsing WCUK for stuff and i found this one ^^
http://www.watercoolinguk.co.uk/ca [...] ts_id=1294
you'll need a reservoir to go with that.
The pump is also a res :D
------------------------------ The Meaning Of Life
Sometimes it's a chicken,
Sometimes it's a chair,
Sometimes its a piece of cheese suspended in the air
it's a very small one, I'd buy that and one of the dual bay XSPC 750 pump/reservoir then a couple of 500cc coolant.
Dont have the money m8 :D will do when I have though
Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > Water Cooling Crisis!
There are 1227 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
