Space problem :(
Forum Graphic & Displays : Graphics Cards - Space problem :(
Hi guys!
I want to buy motherboard Asus P5N-D and also 2x Palit GeForce 9800GTX+ with costumised cooling which looks like this:
http://www.cpu3d.com/media/image/g/9918/i/18454/IMG_2908.jpg
I have no idea if I will be able to fit two of those into Asus P5N-D... Please tell me if it will be fine :(
Sponsored Links
It'll fit in your motherboard as long your board is SLI capable and you have enoug =h room in your case. Look up the specs of the case and compare it with the dimensions of the video cards and see if you have enough spacing.
Reply to vouslavous
It will fit in just into Antec 300 that I am going to buy, however HDD cannot be opposite GPU.
Also I've noticed that second GPU will cover SATA slots. Will L shaped SATA cables solve this problem?
Message edited by tosiek2142 on 03-15-2009 at 02:41:21 AM
Reply to tosiek2142
Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > Space problem :(
There are 518 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
