Yes No
Ads
Tom's Hardware > Forum > Overclocking > Memory > DDR 3 ram problem
DDR 3 ram problem
Forum Overclocking : Memory DDR 3 ram problem
My motherboard is Gigabyte 77OTA-UD3 and my ram is 4 gigs Kingston Hyperx ddr3 1600mhz. The problem is that my ram is runing on 1333mhz and when I clock it to 1600mhz , my pc gives BSOD when starting windows. I've set my ram settings like this http://img816.imageshack.us/img816/9868/ramclock.jpg and I don't know much about overclocking ram. Right know I am using my ram with the same numbers like in the pic but on 1333mhz because as I said on 1600mhz pc crashes. Please help
Pc specs :
Gigabyte 77OTA-UD3
PSU : Cooler master silent pro 600w
Ram : 4 gigs Hyperx ddr3 1600mhz
CPU : AMD Phenom II x4 965
HDD : Seagate 500gb sata2
Sapphire HD 5770 1gb
Also running windows 7 ultimate 32 bit
Reply to Anonymous
Hi nastyduderoxx and welcome to THG.
Can u please post the link of the RAM that u have? For the 1600 u need change a few things in the BIOS for run stable.
Message edited by saint19 on 09-06-2010 at 07:09:43 PM
------------------------------ Installing the CM Hyper 212+
AMD Overclocking Club
Member Rankings: Points, status and badges
Doesn't work? Send me a PM.
Reply to saint19
Can you tell me how to see my exact model , please ?
Reply to Anonymous
its normally on a sticker on the ram, theres a long number with letters, an example would be:- KHX1600C9D3K3/6GX
------------------------------ Current rig:
i7 920 @ 3064MHz.
6gig of Kingston hyper-x DDR3.
Reply to Jak_Sparra
OK , I checked it and it says : KHX1600C9D3/2G
Reply to Anonymous
- 0 +
Nice.
Go to the BIOS and change the following settings:
CL=9
tRCD=9
tRP=9
tRAS=27
Command Rate= 2T
and set the voltage to 1.7V. Test the rig with that configuration and let me know if that works.
Reply to saint19
Hmm I'll do that but is it ok that my dram voltage beyond 1.640 is in red numbers and beyond 1.9 is in flashing red numbers :O just curious I don't wanna do something that I will regret afterwards.
Reply to Anonymous
- 0 +
Your RAM is build for support 1.7-1.9V that IMO is very high for DDR3 since some DDR3 can run at 1.35V. You can check that here and here
Now my advice is RMA the RAM and get a different one with lower voltage max 1.65V if u don't feel comfortable about the rise voltage.
Reply to saint19
There are 1862 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Any news on the Thermaltake Water 2.0 Extreme Cooler?
By amuffin, 13 hours ago:
If it has anything to do with Thermaltake, it's a BAD IDEA.
Best offers
Top experts
