I recently bought a Thermaltake V9 Black Edition case. This case comes with 120mm fans on the front and the rear and 230mm fans on the side and the top. The power supply is going to be placed in the bottom of the case.
So the question I have is what type of fans should the power supply have to work together with the case fans.
-If the power supply has a fan on top would this disrupt air from the side or front fans? Would this be venting hot air right onto my other components?
-If the power supply has a front fan will this disrupt air coming from the front case fan?
-If the power supply only has a rear vent will it be enough to keep it cool?
I also had a question on how the case fans should be positioned (intake, vent) Here's what I had in mind:
Front and side fans: intake
Back and top fans: vent
Thanks for any help. I plan to use this as an overclocked gaming machine, so I figure heat will difinitely come into play.
