G
Guest
Guest
Well i caused this problem and cant figure out how to save all of my data and restore the file system back to NTFS.
This is how it happened. I was trying to install Win7 to my WD Elements 1TB external. I was using the windows fast installer toget it to work because the normal install wont support USB or IEEE1394 connections. I resized the partition (about 700gb of "stuff") and created a second partition about 30gb in size. The fast installer wasn't doing what it was supposed to do and some files were becoming corrupted. I decided it was a waste of time and put the partitions back to how it was before i started this. Now my HDD is showing RAW as the file system. I tried a few different apps to get it back but nothing was working. boot sector is fine but there is an error with the back up boot sector. Some of those apps were saying that i could fix the MBR because of the partitions overlapping. I really want to save whats on there. I do not have the space anywhere else to recovery the files to. I do not want to format the drive. Any suggestions that dont involve destroying the data would be fantastic. TIA -Capn
