Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > Will my power supply power a 260 GTX
hey everyone, i have a 550 Watt PSU and i was wondering if it can power a 260 gtx
talking about the 12 v rails, on the side is says 12V and above it, it says 25a
plz help and thanks
Sponsored Links
I have a 550 Watt Corsair PSU and a O/C GTX 260 (216)... so yes!
Oh but make sure it has the required power connections (I think all GTX260s need two 6 pin power plugs)
Message edited by gtown on 05-19-2009 at 08:38:18 AM
Reply to gtown
ok....uber sweet
its an older one but higher quality
will the two molex adapters be good enough
and to be sure that my PSU could power a 4870??
Reply to UberGenocide
Yeah you can use the molex adapters with the 6-pin space, but I think it takes up 2 molexes to power one 6-pin so you might need four free molexes.
And yes I think the 260's are more power hungry than the 4870.
Reply to gtown
Like gtown said a 550W can power a GTX 260...but can you give the make and model of the PSU as there are some 550W, which are not good enough for the job and you wouldn't want the risk of crashing your components do you...
Reply to gkay09
idk the make nor model...ill just get a crossfire certified that way ill know my components are ok :D
thoughts still welcome
Did you properly check if there is only a single 12V rail with 25a ???
Theoretically you are good to go but if the PSU is very old, then its components might have degraded and it might not be able to provide enough power...
But you can confirm that if the PC would shutdown during game play or high graphics intensive tasks...
Reply to gkay09
its only about a year old...and could you clarify on what 'properly' checking the amps would be
Did you see just 1 12V rail or more...
Just needed a confirmation for the same...
Reply to gkay09
And it doesn't have pcie connectors???
Reply to gkay09
no...but i am powering my 9600 GT OC with just one molex going into a 6 pin PCI adaper
JUST ONE and it runs flawlessly
Well the 9600GT doesnt require so much power as a GTX 260...
The 9600GT is a 96W Maximum Graphics Card Power (W)...where as the GTX 260 is a 182W Maximum Graphics Card Power (W)...
Message edited by gkay09 on 05-19-2009 at 03:41:35 PM
Reply to gkay09
I feel you shouldnt take chaces with that PSU...
$40 could get you good PSU that could run that GTX 260 with the required power connectors...
http://microcenter.com/single_prod [...] id=0294050
But if you still want to run the GTX 260, then its your choice..
Message edited by gkay09 on 05-19-2009 at 03:46:28 PM
Reply to gkay09
i think ill save my hardware by spending the extra 40 bucks XD
thank you for your replies
^ Good decision :)
Reply to gkay09
There are 928 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
