Wireless network problem
Last response: in Wireless Networking
Anonymous
Wireless Authority
Driver Expert
Check the wireless adapter is installed correctly by going to Control Panel, System, Hardware, Device Manager and look under Networking.
check your WZC...go to control panel>Administrative Properties>Services>Scroll all the way down till you see WZC(Wireless Zero Configuration) double click on that....check to make sure that startup type is set to AUTOMATIC and that the Service is STARTED..if not started click start. this should solve your problem.
Ask the community
