Hello
Looking for suggestions and advice for a heatsink for my recently setup new rig. This also have to correlate with my cases' airflow design which is quite unique. The following explanation will throw light on this further.
My rig specs
CPU - Intel I5 760
Mobo - Gigabyte GA - P55 - USB3 Rev 2.0
PSU - Gigabyte PoweRock 500W
GPU - XFX ATI Radeon HD 4670
RAM - Patriot Extreme Performance Gaming Series DDR3 4GB (2 x 2GB) PC3-12800 Enhanced Latency DIMM Kit
HDD - Seagate Barracuda 1 TB Internal Kit
LG Mutidisc writer
Super Rainbow Case - http://www.rainbownsk.com/prodetails.aspx?elmnt=30
Now first thing is about the case. I am using it as a HTPC instead of a tower, so its lying on its side rather than as it is depicted in the picture. There are no side vents on fans. Notice the air vents on the "TOP". The PSU is on the front left side right below the first squarish air vent feeding the psu fan. The other square air vent further down is for the GPU fan intake. I have also attached 2 X 80 mm fans on the backside for exhaust. One more 80 mm fan attached to the inside of top circle vent blowing air into the case which is temp controlled from the case's fan controller in the LCD at front . There is also air vents on the bottom of the case as depicted in the first picture.
Right now i have attached the stock cooler for the cpu. There is a clearance of around 120mm out of the total 360mm height due to the mobo and the fan on top of the case.
The suggestions i'm looking for
1. Is the air circulation apt for this rig (air intake from the psu at front and the 80mm fan on top and two 80 mm fan at the back for exhaust)
2. Suggest a good cpu cooler for this rig. Budget is not a problem.
I overclock occasionally to play a few games but its mostly used for movies and music and general computing. All suggestions are welcome.
My rig specs
CPU - Intel I5 760
LG Mutidisc writer
