Tom's Hardware > Forum > Graphic & Displays > ATI > Problem with new 4870
Forum Graphic & Displays : ATI - Problem with new 4870
Recently I purchased a "Sapphire ATI Radeon HD 4870 "Toxic" 512MB GDDR5" and when I play games like counterstrike source, dawn of war 2 or farcry 2 I get severe artifacting all over the place and occasionally crashes. Also when I try to watch a video the screen goes black then comes back on with VPU recover saying the driver stopped responding.
Im not sure what the problem is, is it a faulty piece of hardware or is something in my system breaking it? I have a 550w PSU with 30A on the 12v rail (Is that not sufficient and causing the problem?)
Sponsored Links
Sounds like overheating. Are you monitoring your gpu temps?
Use something like GPU-Z to check on your temps and loads wen you start seeing those artifacts and colors.
Reply to kingtz
I just loaded up farcry 2 and straight away had artifacts all over the place, the load peaked at 74% and all of the temperatures in gpu-z ranged from around 50-60*c
Reply to Fudgefoice
I would just RMA. Sounds like a bad one, it happens.
------------------------------ The voice of REASON
Do NOT feed the TROLLS!
Always a DEMON!
Reply to 4745454b
- 0 +
Those numbers seem good to me. Another possibility is an unstable overclock, so if you're OCing, just do that stability test in CCC.
It could very well just be the driver. If you're already using 9.2, I'd try an earlier version. 8.12 is the most stable for me and what I'm currently using. 8.10 worked really well for me too. So you might have to try your luck there.
Reply to kingtz
- 0 +
You might want to look at that PSU as well, 30A on the 12v rail is n`t much for a 550W unit, who made it?
Agree with 4745454b; RMA the card, it does sound faulty.
Reply to coozie7
Ok thanks ill try some older drivers and if that fails ill go about RMA'ing it. The PSU make is colorsit
Message edited by Fudgefoice on 03-15-2009 at 08:57:36 PM
Reply to Fudgefoice
Colors4it? Might want to borrow a better PSU just to rule that out.
Always a DEMON!
Reply to 4745454b
- 0 +
I have the exact same video card. Overheating cannot be the problem. The sapphire Toxic is one of coolest running 4870s out there. I mean unless your case has almost no ventalation. As long as you have an intake and an outtake fan the card should be fine. Mine has yet to break 50C. I would say you just have a bad card. I would RMA it. My card works awesome and I have had zero problems with it.
------------------------------ AMD 64x2 5000 Black Edition OC’d @ 2.9 GHz - Sapphire HD4870 Toxic 512MB Videocard - MSI K9A Platinum Motherboard - 2GBs Kingston Hyper-X DDR2 800 - Cooler Master Centurion 534 case - 700W OCZ Game Stream PSU - Windows XP - Logitech Illuminated keyboard
Reply to Rwayne
There are 1350 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
