Yes No
Ads
Tom's Hardware > Forum > CPU & Components > Power Supplies, Cases & Mods > [Power Supply] 4890, others have told me this PSU is fine...
Forum CPU & Components : Power Supplies, Cases & Mods [Power Supply] 4890, others have told me this PSU is fine...
After running some tests using the wattage calculator, and some advice from people here telling me it's enough, my paranoid mind still refuses to be satisfied. I am trying to run an OC 4890 from XFX. http://www.newegg.com/Product/Prod [...] 6814150368
Power supply is as follows:
http://img.photobucket.com/albums/1003/Blade111/PSU.jpg
Is on it's way now. It should be here by friday. Here are my other components.
Antec 900 Case (Stock cooling, no extra fans)
3x USB Devices (Logitech G7, Nostromo N52, Logitech G15 *Original type*)
1x Verizon Fios router (irrelevant?)
1x Maxtor external hardrive that is off most of the time.
1x Acer 22" LCD Monitor
1x DVDRW drive
1x SATA(?) Hardrive. 250.1GB Model : WDC WD2500KS-00MJB0
Inter(R) Core 2 Duo CPU E8400 (3.0 Ghz)
4x Gigs of patriot ram (I cant remember the type, sorry.)
1x MSI P35 Platinum Combo LGA 775 Intel P35 ATX Intel Motherboard
and of course, the coming addition to my
1x XFX ati 4890
Is my supply really sufficient for this setup? What happens if the power supply isn't good enough; can it damage my components?
Reply to Shadar0
I think you need a bit more PSU because it says 230w for the whole system which runs off 12v, so 150w for the 4890, that leaves you with 80w, 65w for the processor, 15w left, 40w for the motherboard, you're out of watts.
Reply to Helloworld_98
28Amps on the 12 V rails is low for the 4890. Maybe the 4850, but low for the 4890
------------------------------ If we lose this freedom of ours, history will record with the greatest astonishment, those who had the most to lose, did the least to prevent its happening
Reply to JAYDEEJOHN
- 0 +
Oh boy, I wish I had done more research before grabbing the 4890 then... Anyone else have something to add? I was told by several other people that I "Should be fine".
Reply to Shadar0
Ill put it this way. It may run, if the PSU is brand new, but after awhile, itll crash, and could bring other componants with it when it does
Reply to JAYDEEJOHN
- 0 +
So, what would you suggest I get to replace my old PSU? Something I was considering doing at first until I was told by people on this forum that I should be ok with this?
I was considering THIS before I was told I didn't need it.
http://www.newegg.com/Product/Prod [...] 6817139006
Message edited by Shadar0 on 05-19-2009 at 10:14:46 PM
Reply to Shadar0
a high-end 500w will do the job, just make sure it has dual 6 pin power connectors, or 8pin and 6pin if you have one of the 1ghz cards.
- 0 +
I was told ultra is a mid grade brand, also; the PSU is years old. I think it's about 3-4 years old at this point. I bought it during one of fry's more famous deals (it was free after the rebate).
Reply to Shadar0
^5 +1 what the Forum Master said.
First, the psu in the photo is an Ultra V Series 500 watt power supply. The +12 volt rail is rated at 28 amps. Not exactly a high quality, high performance psu.
Second, an ATI Radeon HD 4890 (1GB) video card uses about 285 watts at full load according to the Tom's hardware review of the card:
http://www.tomshardware.com/review [...] 62-13.html
Third, here are links to technical reviews of the Ultra power supply:
http://www.legitreviews.com/article/465/1/
http://www.hardwarecanucks.com/for [...] eview.html
A high quality power supply in the 500 to 500 watt range can easily handle any single video card made. However, based on the power requirements of the 4890 video card and the technical reviews of the Ultra power supply, I would recommend purchasing a brand new high quality power supply.
EDIT - Although Corsair has a solid reputation for high quality power supplies, the TX 750 is overkill for your system. The TX 750 was designed for use with mutiple video cards in dual SLI or dual Crossfire mode. All you really need for your system is the Corsair VX550. It has a single large +12 volt rail rated at 41 amps. It can handle any single video card made and quite a few mutiple card configurations:
http://www.newegg.com/Product/Prod [...] 6817139004
Message quoted 1 times
Message edited by JohnnyLucky on 05-19-2009 at 10:44:48 PM
Reply to JohnnyLucky
- 0 +
Not a bad price on that PSU, but tell me; wouldnt it be worth it to just pay the 20 dollars extra to be prepared for any future overclocking I might do to my processor?
Reply to Shadar0
Here's a link to a technical review of the Corsair VX550:
http://www.jonnyguru.com/modules.p [...] ry&reid=62
Overclocking is not an issue. A high quality 500 to 550 watt psu can handle an overclocked quad-core cpu. Your cpu requirements are lower. The real issue would be using one video card versus using mutiple video cards. If multiple, power hungry, high end video cards are in your future plans, then go ahead and spend the extra $20.00.
- 0 +
Thanks a lot for the help, I don't really plan (or have the wallet... or patience) to deal with any SLI / crossfire in the future. I'll go ahead and grab the 550w on ebay and hope that I've gotten good advice this time, though looking at the review; it is difficult to refute any words said here.
Reply to Shadar0
ebay? A brand new one costs more on ebay:
http://cgi.ebay.com/Corsair-VX550W [...] 7C294%3A50
Here's a better deal at buy.com - $88.74 and shipping is free. There's also a rebate for $20.00:
http://www.buy.com/prod/corsair-55 [...] caid=15890
That's for the whole system at the wall.
------------------------------ 24 threads @ 4GHz
Reply to theAnimal
- 0 +
Did I actually type in ebay? Im sorry, Ive been trying to sell my refurbished 8800GT, so I probably typed that without realizing it.
I use newegg for all of my electronics.
Hm, with the buy.com 30 dollars off, and the mail in rebate, the PSU would be a real bargain, unfortunately, Im pretty sure Im not eligible for the 30 dollars off being that I have the Amazon iteration already. Still, it's a good deal... If you dont mind getting a visa cash card thing.
Also, does the 550VX have two 6 pin connectors? On the specifications it lists a 6 pin PCI-E and a 6+2pin PCI-E (Whatever thats supposed to mean).
Message edited by Shadar0 on 05-20-2009 at 01:50:24 AM
Reply to Shadar0
theAnimal - GEEZ! Darn charts and articles are confusing. Some measure just the video card and some measure the entire system at the wall socket. No set standard. It's bad enough I am growing old disgracefully.
Shadar0 - Yes, the VX550 has two six pin connectors. That 6+2 pin can be used as either a six pin connector or an eight pin connector. No problem.
Message edited by JohnnyLucky on 05-20-2009 at 04:19:22 AM
- 0 +
I see, I should have figured as much; but I guess it's good to be on the safe side.
Well, I'll be picking this PSU up; hopefully, I wont get a dud.
Reply to Shadar0
- 0 +
I have one more quick question before I buy, sorry.
http://www.newegg.com/Product/Prod [...] 6817139005
I found a 650w corsair for one dollar cheaper than the 550VX I was linked earlier. Would this be a good idea?
Reply to Shadar0
It looks good. @52 amps on the 12V rail, itll handle everything you could possibly do to your rig, like ocing, adding other components etc
Reply to JAYDEEJOHN
- 0 +
The reviews seemed favorable as well, as it's (apparently) a higher quality Seasonic build.
Thanks a lot for the help.
Reply to Shadar0
YMW, and have fun with that new card
Reply to JAYDEEJOHN
I have a LC Power Fonte 500W LC500H-12
DC OUTPUT +3.3V (20A)
+5V (22A)
+12V1 (15A)
+12V2 (15A) -12v (0.8A)
-5V (0.5A)
+5VSB(3.0A)
Skt am3 dual core 240,OC to 3,5ghz ,2xhdd sata,1x120mm fan,Onboard grphics.
I just BOught a 4890,i will be changing PSU soon.But i would like to test the 4890 if its fully working, since it´s used..
Any risks if i only plan to use it in Idle mode? What about gaming/Full load.
I have gone to
http://www.extreme.outervision.com/PSUEngine
Less then 300W in teh test,still im like....Relutante:(
Reply to Silent321
- 0 +
Corsair and Antec are my PSU brands of choice (3 Corsairs and 3 Antecs). Either brand, 550 watts or larger will do.
Reply to jsc
There are 1835 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Cpu Temperatures higher than normal by a far margin !!
By rolli59, 2 hours ago:
If properly mounted!
Best offers
Top experts
