Tom's Hardware > Forum > Motherboards & Memory > Gigabyte > Front panel audio connections to mtherboard and case Hd audio or AC97
Forum Motherboards & Memory : Gigabyte - Front panel audio connections to mtherboard and case Hd audio or AC97
HELP, panic, could someone research for me! DO NOT want to blowup moterboard by hooking up wrong or wrong connector! I've tried researching but still don't know if can just plug in and which one.
Do not have a clue on hooking up front panel audio header, case comes with two 10 pin connestors.
(one HD audio and one AC 97, these connectors are all one piece can't seperate wires individualy.)
I have a gigabyte GA-MA790X-UD4P and RAIDMAX AZTEC ATX-619WB Computer Case.
Building for my son, my first computer build.
He will just be using headphones on front audio connector (maybe microphone later).
Sponsored Links
Use your motherboard manual. It will label where each port is. Your motherboard probably has a connection for both types of audio. The two different cables should be labeled with a little flag. Also, your not going to blow up your motherboard.
------------------------------ i7 920 | Scythe Mugen Cooler | Asus P6T | OCZ Gold 6gb | Asus Radeon HD4850 TOP @ 680Mhz | Western Digital Caviar Black 1TB | Corsair 650w | Cooler Master CM-690 | Asus 21.5" (2) | Windows 7 x64
Reply to jsrudd
Oh, no. Not this question again.
At the risk of sounding rude, RTFM.
Read the freakin' manual.
(As I leaf through my GA-EP45-UD3P manual)
A section in the front of manual lists specifications. A section later talks about internal connections. Those say the motherboard supports HD audio by default. A third section in back describes how to change it to AC-97.
Your case included both connectors so it could be compatible with both old and new motherboards, nearly all of which support HDA.
Message edited by jsc on 07-26-2009 at 08:41:59 PM
Reply to jsc
Use the HD connector from the case; it is the default in the BIOS, supports features not on AC97...
There is only one connector on the MOBO:
http://img196.imageshack.us/img196/2298/0032xkw.jpg
DO NOT cut the unused connector off the case's cable; on most cases, the HD ID jumper (-ACZ_DET) is 'made' through a connection on the AC97 connector; if you want to get rid of it, takes modification...
Reply to bilbat
Thanks for the HELP and guidance, first time doing something a little slow sometimes, and paranoid when seeing jumpers on connector and seeing labeled (+5V on case manual and -acz_det on motherboard manual, etc.) different.
I have read the motherboard manual, my confusion is case manual had different labels for motherboard pins and showed case connections as individual wires and my actual case has all wires in a single connector. So I have no idea what wires are connected to, only 1 single label on connector HD Audio or AC 97, where as case manual has individualy labeled and landed on individual pins. Just hope they have it wired right to some standard way of doing things.
I just need to ignore case manual as it is actually a GENERAL diagram not specific to my moterboard.
???Question if I plug in and try to use ac97 or the default HD Audio is it possible to burn up moterboard.???
Reply to wlmz
No risk in plugging it in; notice that, on the MOBO diagram, pin eight is 'missing' from the header layout; if your case manufacturer 'did their job', there should be a corresponding 'blocked hole' in your plugs - you should not be able to plug them in incorrectly. The plugs themselves 'tell' the motherboard which one they are - the difference being that if you use the AC, you have to enable it in the BIOS. Again, I recommend the HD plug, specifically, because it supports 'muting' when headphones are plugged in...
Reply to bilbat
Thanks again from newbie, doesn't sound like much of a problem then.
I had read somewhere you could fry motherboard if wires on wrong pins (maybe for the individual wire type?) so didn't have time to RMA motherboard so being super cautious.
I will post back if problem, but seems simple for now.
Reply to wlmz
The UD3P/4P/5P is designed to be relatively n00b friendly so it has a pretty high tolerance for wiring errors. If something is catastrophically wrong it'll kill power to most of the boards components.
Message edited by J0SEPH on 07-26-2009 at 11:13:58 PM
Reply to J0SEPH
Use the default HDA. You have nothing to lose. Make sure you use the chipset drivers from the included CD.
The results are kind of cool. You plug a headset into the jack and the board detects it. You get a graphical popup that asks you what you just plugged in. And you just click on the headset.
And wlmz,
I apologize. I am getting old and crochety (my wife would say "getting?" :)). Sometimes, I forget that I built my first computer a long time ago, back when "build" meant taking soldering iron in hand.
Overclocking since 1978 - Z80 (TRS-80) from 1.77 MHz to 2.01 MHz
Reply to jsc
:lol: (too bad they don't have a crochety old fart smiley) KayPro Z80 pushed from 2.5 to 3 with megabyte of ramdisk (mind is fortunately blank about what that cost me), Seagate ST-225 20 M HD (three partitions!), hand soldered two-level FDD decoder chips to get 'high-density' (think it was 784K or some such) 5 1/4s, running ZCPR-3; think it was '82 or '83...
Reply to bilbat
Hey, my wife swears they made a movie about me - "Grumpy, Old Men". I tell her that I don't think I'm that old.
Seriously. 82 or 83 sounds about right. I had a Kaypro II. That was a Z80A running at 4 MHz. Bumped that to 5 MHz. Had to replace the video controller. Wasn't ZCPR-3 great?
Back to the OP. wlmz, how are you doing with your build?
Reply to jsc
One more stroll down memory lane: remember how great it was to have actual schematics for your actual motherboard? I'd be willing to kill someone for a set now... (Or BIOS source code, for that matter...)
Reply to bilbat
bilbat, I'm moving my reply to private messages.
Let's give the original poster his thread back. :)
Reply to jsc
There are 543 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
