New Build Temps Advice
  • CPUs
  • Build
  • New Build
Last response: in CPUs
May 20, 2009 6:53:31 PM
I recently built my 1st build, i posted a few questions on here in the build, thanks for the advice people. anyway ive been up and running for just over 2 weeks. When im ideal im running at about 36oC. Im running a i7 920, not overclocked and im using a titan fenrir cooler with a coolermaster haf case. here are the results after while running prime95, small ftps test for about 10mins.
are these ok temps? im just wondering.
thanks.
More about : build temps advice
May 20, 2009 10:14:21 PM
Looks normal to me, but it seems that your heatsink may be the culprit. I have the same temperature, yet I'm using a stock Intel fan (a true POS).
May 21, 2009 2:04:51 AM
Not 100% sure what the operating temps for i7 are, but I always feel a bit off if I see prime causing temps higher than 70...
Recheck your HSF and thermal paste.
May 21, 2009 5:39:13 AM
Ok thanks, with the titan fenrir how much paste should i apply, i applied a thin layer across the whole chip?
