At this half year, the Intel’s core i7 is the key promoted product of the high-end product line.
The users are really easy to run out their budget while the CPU is still not cheap at all….
But the pricing of X58 motherboard is a bit “flexible” than the CPU’s.
So, some of the manufactures have already launch their entre-level X58 mobos.
The price of them are around USD200 ~ 200.
It’s much cheaper that compares to the highest-end models.
Recently, Intel is going to launch their Core i5 (LGA1156) processor. It’s around the corner.
For the different segment of the market, Intel will place Core i3, Core i5 & the Core i7 as the value, mid-range and high-end product.
After the launch of Flaming Blade, FOXCONN releases a step-lower model, called Flaming Blade GTI version.
The price is around USD183.
First, take a look at the package design.
Although it should be a value X58 board, but FOXCON still make it as a high-end product design. Looks like a high-end product.
A big box package and some details in the back for the spec too.
FOXCONN Flaming Blade GTI, the board.
In this market segment, the ordinary capacitors are the reasonable choice.
The bundling:
User Manual, Easy guide, Drivers and Utility CD, IO shield….etc.
The lower-left part:
2 X PCI-E X16 slots
(supports2 X 16X之ATI CrossFireX)
1 X PCI-E X4 slot
2 X PCI slots
The LAN chip: Realtek RTL8111C
The audio codec: Realtek ALC888,supports 7.1 channels HD audio.
The lower right part:
6 X SATAII (ICH10)
1 X IDE
The debug light
The upper right part:
3-channel DDR3, support 1333/ 1600/ 1800, max support up to 12G
The left plug is the 24pin power input.
The upper left
This is LGA1366 socket, but Foxconn keep the 775 cooler’s mount hole.
A real smart design for users
The CPU power supply parts, the board put 6-phase PWM on.
I think it’s enough for i7 normal usage.
FOXCONN Flaming Blade GTI version is not support SLI.
The capacitors are all not solid state capacitors, and they put away the eSATA also.
These are the differences of FB and FB GTI.
Starting Screen
BIOS MAIN PAGE
OC options page
CPU Features
DDR3 reference page, XMP, where the auto OC technology within.
The voltage parts:
CPU Core Voltage +10~1260mV(CPU, max: 2.54750V)
CPU VTT Voltage +20~1260mV
DRAM Voltage 1.50~2.86V
CPU Vdroop Compensation,This is for prevent the voltage go down when OC the Intel chipset
X58 IOH Core Voltage 1.10~1.60V(the interval is 0.02V)
OC gear
The system provides totally 8 storage spaces for Users to save their OC settings.
Hardware Monitor
The above is my test, stable at 200/1600.
I think you can do that on your own for some special settings.
The configuration of XMS3 DDR3 6GB 1600 CL8 is a bit conservative.
So, I make it as 1600 CL7 7-7-20 1T can run steady.
I end up with CPU 200Mhz. DDR3 runs at 2000MHz CL9 (system can get into the OS and run the OC testing)
The Corsair XMS3 (DDR3 1600), the OC ability is above the standard.
CPU part
Intel Core i7 950
OC 200 X 21 => 4200Mhz
DDR3 1600 CL7 7-7-20 1T
OC 191 X 23 => 4401Mhz
DDR3 1913 CL9 9-9-24 1T
Hyper 4 X PI 8M 1m 50.090s
CPUMARK 99 688
Install with my i7 950, the system can reach 8 PI 32M stably by 1.212V.
The maximum of CPU can be around 4.4G.
The maximum rate of overclocking of this D0 version (i7 950) seems a bit improved than previous vision.
VGA 3D Rendering
By MSI N9600GT Diamond
3DMARK VANTAGE 5398
Crysis Benchmark
THE LAST REMNANT
Street Fighter IV Benchmark(Display V-synch ON)
1920 X 1200
9600GT display card is a mid-range level product.
If this VGA co-op with i7 CPU, I think most of the games can run quite smooth (of course not open too much effect)
BTW, this GTI version doesn’t support SLI; hence, you have to use ATI cards when you wanted to install dual VGA display.
FOXCONN Quantum Forces series/ Flaming Blade GTI
Goods:
1. entry-level price for X58 board, but the packing is still very high-end
2.BIOS options are various. Almost the same to mid-range level Quantum Force Mobo
3.The OC ability is quite good in the way. The OC performance of CPU and DRAM are obviously nice.
4.A bit earlier, the cheaper X58 is around USD200, Flaming Blade GTI version only needs USD180.
Drawbacks
1.No back up supports for NVIDIA SLI
2.The south bridge is only use ICH10.
3.Hard to buy in the channels as usual
Performance: ★★★★★★★★★☆
The Components design: ★★★★★★★☆☆☆
Specification: ★★★★★★★☆☆☆
The appearance: ★★★★★★★★☆☆
C/P Ratio: ★★★★★★★★☆☆
The X58 products are being mature in the market.
Due to the positioning of the chipset, it is a Top-ranking product.
Hence, the chipset is relatively high in price. Most X58 motherboards in market is around USD 200 to 300.
The segment is quite complicated too.
FOXCONN Quantum Force series try to release a step-lower X58 model.
But for the budget consideration, the components and functions are a bit reduced than before.
If this is for a budget user, this Flaming Blade GTI is a best choice for gamers.
The OC ability of Flaming Blade GTI version is inherit from Flaming Blade and BloodRage. It’s quite up to the standard.
If you want to spend more to get a board, which has better components and maybe can use both SLI and CF.
I suggest that you should try the Flaming Blade, not GTI version.
