Tom's Hardware > Forum > Motherboards & Memory > DFI > No Power on- Power Supply is good. Computer was LITERALLY just working
Forum Motherboards & Memory : DFI - No Power on- Power Supply is good. Computer was LITERALLY just working
Okay, first here are my specs
Antec Truepower 430w
DFI P45-T2RS
Intel E5200
ATI 4850 512mb
4gb OCZ Reaper DDR2800
Fans+Watercooling setup
250gb Seagate
Blu-ray drive
Here's my situation:
My original Power supply, an OCZ 500w modular, broke 2 days ago. I just borrowed my friends antec while waiting for an RMA. I powered up my computer using the Antec and everything was fine. (The wattage is REALLY close but the antec has good amps so I guess it's enough). I used my computer for a few hours then put it to sleep. Later, I came home and turned off my computer. I then tried to turn it back ON and nothing happened...sooo...wtf basically. One other thing: I have a standby light on but the DRAM motherboard Power LED is NOT on so for some reason I'm guessing my motherboard just isn't getting power...
Here's what I've done so far:
I have tested the power Supply. (working)
I have checked all power and Data connections (correct and secure)
I have removed PCIE cable to ensure it's not a problem of insufficient power (didn't help)
I have removed one and then both memory modules (nothing)
I have removed ALL cables from the back of the case.
I have hit my head against my desk (painful and unhelpful)
Does anyone have any ideas?
again; my computer was WORKING then I turned it OFF and now it WONT turn on. I get NO sounds NO Fans NO NOTHING.
Thanks for any and all help.
Message edited by Dieselroar on 07-27-2009 at 07:49:07 PM
Sponsored Links
How did you test the power supply? Did you try another power supply with your system?
------------------------------ Desktop | E7300 | P5KPL-AM | 2GB DDR2 667MHz | NVIDIA 9500 GT | ST3320613AS | w2228h
XPS M1330 | T8300 | Dell 0U8042 | 2GB DDR2 800MHz | NVIDIA 8400M GS | WD2500BEVS-75US | 1280 x 800
Reply to r_manic
I used a power supply tester first then I used a paper clip to run the watercooling the lights and the fans alone.
Reply to Dieselroar
There are 1119 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
