I have a phenom II 555be. It unlocks to 4 cores. I was told that I could easily overclock it to 3.6ghz when unlocked.
My system
Gigabyte GA-MA785GMT-UD2H mobo
XFX HD 5850
Corsair 620hx PSU
Phenom II x2 555be --> unlocks to 4 cores
Cooler master hyper 212+ with 2 fans
In speedfan the other temps were hotter though, temp1 and 2. But the cpu temp was lower. normal? These are just with prime 95 and speed fan running.
temp1: 32
temp: 49
temp3: 42
Core: 38
just the locked 555be cores at 3608.15ghz temps in the OCCT test were from 36-38 celsius.
I am going to do the same test but unlocked at 3608.15 ghz. I'll update with my results. But can anyone explain the temperatures I am getting?
My system
XFX HD 5850
Corsair 620hx PSU
temp1: 32
temp: 49
temp3: 42
Core: 38
