Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > Thermaltake Armor+MX: Stand-off Hole Too Small
Forum CPU & Components : Power Supplies, PC Cases & Case Mods - Thermaltake Armor+MX: Stand-off Hole Too Small
When screwing in the standoffs for the motherboard in this case, the last hole needed would not accept a standoff. It would only screw in one turn, leaving the majority of the thread still exposed.
According to the manual this hole should take a stand-off. Also, there is a hole on my motherboard correlating to the hole site in the case. The only thing I can visibly separate between the holes that accept standoffs and the one that doesn't is labeling beside them. Acceptor sites have AFM while the one that won't screw has only AF.
Is there something I'm missing here or could this be a factory defect? Also, is one missing standoff even an issue, especially when ist in the lower corner of the motherboard?
Message edited by virginiaviking80 on 05-21-2009 at 04:23:37 AM
Sponsored Links
Probably a defect. That happened to me years ago. I used a pliers to screw the darn thing in. I probably stripped the threads on the standoff but it worked.
Reply to JohnnyLucky
There are 463 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
