this has been going on for 4 months now. Started with a power spike or something. The computer would not boot, as it "lost" the hard drive. Replaced the HD and now it would not post. Took it to the shop and found the CPU/MB were toast. OK told them to upgrade the system. The new MB needed a 8 pin power lead, the old PSU did not have so told them to replace that also. It is done and all set up with XP and runs great at the shop. Bring it home, and decide to upgrade to 8 gigs of RAM. Put it in and set it up and now I get "No Signal Detected" from the Monitor.
I have one idea to change the RAM back and try it. Seems like there power to the GPU, the fan is turning.
Looking for more ideas to try as I get time to work on it. So busy at work, no time at home.
