Drive door will not open, Optiarc DVD drive AD-7231s5 scsi cd
Hello
I am not really good at this, but need some help
I have read the info from the side of the computer to tell you what
it is
hp pavilon p6331 p-b bundle
has windows 7 home premium 64 bit, (whatever that means?)
has a Optiarc DVD drive AD-7231S5 SCSi cdRom that says it is a
super multi DVD burner with light scribe technology (whatever that
is?)
The dvd/cd drive was working fine, watched a movie, last week,
and now this week the dvd/cd drive door will not open
Some told me to use a paperclip in the small hole on the drive to
open it but it does not open.
how do i get the dvd-cd drive door to open?
Can anyone help me?
zoezeddy@myway.com
1 answer Last reply
More about drive door open optiarc drive 7231s5 scsi
  1. You push the paperclip into the hole to release the lock inside, then if it doesn't open by itself you have to pry the sliding tray open. using a screwdriver or something else that's pretty thin. There can be a fair bit of resistance, but it should slide out as long as you've been able to release the lock.
DVD Writers CD Drives DVD Drives Storage
