Hey guys,
Pretty much I just got a promliatech megahalems cooler with 2 cooler master 120mm 90 cfm fans running a push/pull configuration. I'm using Indigo Xtreme TIM and I don't think I'm getting the right temperatures. Running a i7 920 at stock speeds. Mid tower case by coolermaster got it from china but it's similar to this one except without the side exhaust:
http://www.coolermaster-usa.com/product.php?category_id=19&product_id=2969
Coolermaster USP 100
I'm getting high 30s low 40s at idle and around 50 degrees at load. Room temperature's 24ish.
I'm using Scythe 120mm casefans running at 113.2 cfm (I think)
Is this normal? Or should I reapply the TIM?
Thanks in advance
Thanks in advance
