External or custom power supplies
Forum CPU & Components : Power Supplies, PC Cases & Case Mods - External or custom power supplies
I have a Gx280 dell optiplex small desktop. intel Pentium 4 3.0 ghz processor, 2gb DDR2 Ram, Intel(R) 82915G/GV/910GL Express Chipset Family 128 Mb (graphics card).
So anyway i want to upgrade my power supply for a new graphics card but the best dell offers is 280( or 250). Which really can get me much.
so i was wondering if there was anywhere that offered either a better replacement for the power supply, or offered external or custom sized power supplies.
Sponsored Links
Have you checked PC Power & Cooling web site?
Click on the details icon to check for compatibility.
http://www.pcpower.com/products/power_supplies/dell/
Reply to JohnnyLucky
in the compatibility it says it supports dell gx280 but it doesnt say which form. Im assuming its not the small desktop form because it doesnt look like it would fit.
Reply to blackbrawler
What is the width of your case?
What is the width of your power supply?
I called they said it wasnt for the gx280 small destop version. I also talked about their custom options and they said it cost 50,000 for the first model.
Message edited by blackbrawler on 05-22-2009 at 10:57:31 PM
Do you have room for a 5 1/2" dvd expansion? If so, there are some auxiliary psu's for vga cards that fit in that slot.
Reply to geofelt
yeah i do have an extra dvd slot(not sure if 5 1/2". Could you go into more depth into what an auxillary Psu is?
Something like this:
http://www.newegg.com/Product/Prod [...] 6817104054
Reply to geofelt
I could kiss you right now man (no homo). I have been looking for an answer to this problem for ever. One more question though what exactly is a dvd expansion slot size. How would i know if it is 5 1/2 ". Is this a standard size for all extra slots? My Gx280 does have a DVD Rw player and i would mind taking that out.
5 1/2 is a standard size for dvd installations. Possibly excepting the thin slot types that you see on laptops.
Reply to geofelt
That PC Power Cooling PSU isn't the SFF version, I'm thinking its the mid-tower one.
Reply to AKM880
yeah your right it is mid tower only.
I did some research on auxiliary power supplies i didnt get much but i found out but needs a cord. does the newegg one come with the cord or is my main PSU expected to have it.
EDIT:
I looked up some more and i think i need a PATA connector which im pretty sure i have.
Message quoted 1 times
Message edited by blackbrawler on 05-23-2009 at 03:43:49 PM
EDIT:
It looks pretty simple to me. No added power cord is needed, no pata connector is needed.
You install the unit in a dvd cage.
There is an internal power cord that leads to a standard back panel attachment. The supplied power cord plugs into that. (Yes, you need a second outlet or a power strip)
There is included a harness that plugs into the back of the unit, and the other end is a set of pci-e connectors that goes into the vga card.
A standard 4 pin molex connector plugs into the back of the unit. It's sole purpose is to tell the unit to power on when the pc powers on, and to power off when the pc is powered off.
Look at the photos of the unit on newegg and it's parts.
Reply to geofelt
I looked up some reviews onnit and i completely understands how it works now. I posted before i looked at the reviews so i had no idea what i was talking about. Anyway thanks a lot man you really helped me out.
Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > External or custom power supplies
There are 1200 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
