This will be my first computer build and I've run into a wall that just widens every time I try to go around it. I will be using this computer for video editing and encoding. I'm looking at trying to keep this build under $1,000. The last two-and-a-half months have been spent researching buying a prebuilt computer or building my own. I don't know if building my own will really cheaper up front, but after seven years with a Dell Dimension 2100 and the limited ability to upgrade/expand, I've decided that extra upfront costs will save money and headaches later.
Now to the meat. I've gotten this far with my build:
Antec Sonata Plus 550 Black/Silver with 550W Power Supply
Gigabyte GA-EP45C-UD3R Socket 775
Intel Core 2 Quad Q9400
G.Skill 4GB (2 x 2GB) DDR2 800 (PC2-6400) Dual Channel Kit
OR
OCZ SLI-Ready Edition 4GB (2 x 2GB) DDR2 800 (PC2-6400) Dual Channel Kit
OR
Crucial Ballistix 4GB (2 x 2GB) DDR2 800 (PC2-6400) Dual Channel Kit
750GB Western Digital Caviar Black WD7501AALS 7,200 RPM SATA 3.0Gb/s Hard Drive
LG 22X DVD+/- Burner with Lightscribe Black SATA Model GH22LS30 - OEM
Windows Vista Home Premium SP1 64-bit for System Builders
As you can see, I'm already not sure which RAM is best, but the wall widened this evening whenever I talked with tech support at Micro Center hoping to get some help with a graphics card recommendation. He huffed and puffed because I hadn't already purchased a system or component(s) from Micro Center until I pointed out that customer service connected me. He gave me a SKU number that doesn't seem to exist on their website. But he did say I need a dual graphics card that supported CrossFire or SLI. He also pointed out my selected mobo wouldn't support said dual cards.
So now I turn to the experts I should have several hours ago. Sorry. I need some help on both a graphics card that can take the load off my CPU while encoding/editing video as well as a mobo that will work. I'm leaning toward Intel Core 2 Quads since my research indicates these work well with such tasks, but I won't turn down AMD suggestions.
Any help would be Oscar-worthy,
moviefan
OR
OR
moviefan
