Tom's Hardware > Forum > CPU & Components > CPUs > Does lowering CPU core speed save power?
Forum CPU & Components : CPUs - Does lowering CPU core speed save power?
I have phenom 9850 BE which i downclock to 1ghz(set at bios=x5), ram to 200Mhz. By doing this, did i lowering my electric usage? I used W7 and play game with no performance impact.
Sponsored Links
Most likely, yes. I would like to say absolutely yes, but you can't say that if you don't actually test it. ;) Component temperatures tend to rise as more power is used, and tend to decrease when less power is used. If the temperature also dropped it's pretty much guarantied that your power consumption dropped.
Reply to NavySEALBrian
a bit but not as much as lowering vcore.
Reply to Helloworld_98
- 0 +
Will the reduced power consumption noticeably affect your electric bill? I doubt it. Greater effect if you turn off the computer whenever you are not using it.
Reply to jsc
Lowering the clock speed won't drop power consumption much unless Vcore is dropped too.
I don't know why you don't just use Cool n Quiet, I've got it enabled using Vista and when I choose power saver my Phenom 9850 remains at 1.250Ghz, Balance allows it to automatically scale between that and 3.0Ghz, and Performance leaves it at 3.0Ghz constant.
Reply to loneninja
- 0 +
If I remember correctly, power scales directly with core speed, and directly with voltage squared. So, you have saved some power, and if you decrease the voltage as well (it should run at the lower speed with quite a bit less voltage), you'll decrease the power even more.
------------------------------ Asus P6T deluxe
i7 965 @ 4.2GHz (200*21), 1.384V
12GB Corsair Dominator DDR3-1600 CAS 7
Reply to cjl
There are 646 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
