Yes No
Ads
Tom's Hardware > Forum > Overclocking > Heatsinks & Air Cooling > [Solved] Pin mount cooler
Forum Overclocking : Heatsinks & Air Cooling [Solved] Pin mount cooler
Best answer from BeCoolBro.
any one know of a HSF, pin mount / surface mount that has a lower profile? I am not looking for extreme cooling, but something decent to replace the Intel stock HSF. I do not want to pull the mobo, at least at this time.
Thank you.
Reply to jerryl
ARCTIC COOLING Freezer 7 Pro Rev.2 I successfully used the original version for 4 years on thee different boards/CPUs (all socket 775).
Reply to treefrog07
Thank you.
How about the scythe big shuriken?
http://www.newegg.com/Product/Prod [...] 6835185129
Reply to geofelt
Best answer
Thank you.
I recommend you get a cooler with a backplate like the hyper 212 plus because I've had the worst experience with push pins.If you insist on getting a push pin cooler,when you install it,if you fail to make the push pins go through the holes the first time and you hear the click though,don't forget to turn pushpin the other way before you try again.If you forget this and try to push it through it won't go in,and if you push it too much it might break like mine did.So to avoid all that trouble take off the motherbard and install a proper cooler.
Reply to BeCoolBro
Pushpin mount can be OK if you do it properly.
It is a pain, but the ONLY way to mount the cooler is to do it with the motherboard outside of the case.
1) The pushpins are hard to get down. If you try to do it with the mobo in the case, you will bend the motherboard and possibly cause other problems. Just put the mobo on a piece of cardboard.
2) You need to be able to look at the back of the motherboard to be certain that all 4 pins are through and locked.
First, look at the cooler, and play with the pins, until you understand how they work. Read the Intel instructions that came with your cpu. The trick is to push in a diagonal pair of pins at the same time.
I agree with BeCoolBro that backplate mounts are better, particularly if the cooler is large and heavy.
Reply to geofelt
Best answer selected by jerryl.
------------------------------ i7 930 @ 4.0 (191 x 21)> ASUS P6X58D-E the best! > Corsair 3x2GB (6GB) > Corsair 850W so sweet > Sapphire 5770 > Thermalright 120 Extreme Rev C the absolute coolest > Master 310B case >3 x case fans
http://valid.canardpc.com/show_oc.php?id=1407547
Reply to jerryl
eh, took the plunge and did the back plate thingy, you conviced me, especially the part about maybe having to check the back on a push pin mount.
Got the Thermalright 120 eXtreme.....and loving it.
Reply to jerryl
Great,I'm really glad to have helped :D
Reply to BeCoolBro
There are 1876 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Any news on the Thermaltake Water 2.0 Extreme Cooler?
By amuffin, 13 hours ago:
If it has anything to do with Thermaltake, it's a BAD IDEA.
Best offers
Top experts
