Power supply question.
Forum CPU & Components : Power Supplies, PC Cases & Case Mods - Power supply question.
Could a very cheap power supply damage any components of the computer?
Sponsored Links
If a power supply somehow dies, it could possibly take other components with it aswell.
Reply to AKM880
- 0 +
If you are lucky, the PSU will shut down electronically. If you are unlucky, the PSU will quietly die. If you are really unlucky, the PSU can fail catastrophically, like burst into flames or components explode, and take other major components with it.
With major vendors regularly running sales and rebates, if you shop arond long enough, you can find some good deals out there.
Message edited by jsc on 05-23-2009 at 12:18:26 PM
Reply to jsc
- 0 +
http://www.corsair.com/cinema/movie.aspx?id=622747
That's worth a smile every time I see it.
Stick to Antec (my personal favorite), PC Power & Cooling, Corsair, Seasonic, or Enermax; perhaps FSP. Check out competent technical reviews (including load testing and waveform analysis) at www.jonnyguru.com, www.hardocp.com, www.hardwaresecrets.com, and also at www.xbitlabs.com.
If it is 80+ certified and has active PFC (no voltage switch), it is most likely reasonable, and could be outstanding. If it has "max" in its name and is NOT Enermax, (e.g. Raidmax, Coolmax, Powmax), the "max" is probably a reference to the magnitude of the pyrotechnic display, or to the number of other parts it will take with it when it croaks.
Reply to jtt283
That's worth a good laugh, thanx
------------------------------ q9650 @ 4.050 | Asus Rampage Formula | 2x2 Corsair Dominators | WD Black 640 x2
EVGA GTX260 Core216 @ 686/1479/1103 | Antec TPN 750
Reply to DellUser1
- 0 +
^ Nice one jit283 :lol:, stick to the brand names jit283 has stated. I personally like Corsair and FSP.
Reply to AKM880
Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > Power supply question.
There are 1059 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 vianescute won the Freshman badge
  • 01:00 meywd won the Freshman badge
  • 01:00 nayega won the Freshman badge
  • 01:00 gpfear won the Freshman badge
  • 01:00 Conrad925 won the Freshman badge
  • 01:00 skythra won the Freshman badge
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
  • 01:00 patlabor44 won the Uniformed badge
