Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > NEED HELP..Antec 902 FRONT PANEL AUDIO STATIC
Forum CPU & Components : Power Supplies, PC Cases & Case Mods - NEED HELP..Antec 902 FRONT PANEL AUDIO STATIC
Hi everyone.
I recently bought the Antec 902 case to replace my old modded cheap one..Problem is whenever I use the front panel audio out jack, I hear an irritating continous static. The rear I/O panel audio jacks does not share the problem.
What's causing this static? Is there any way to fix it?
Any help will be appreciated.
Sponsored Links
The Antec 902 should come with 2 connections for the front audio audio jacks. There is an AC’97 and a HDA connector, make sure you have the correct one connected, and make sure you have it connected to the correct port. If you know you have it connected to the correct port, then try switching to the other connector. More importantly, if you are use an extender to lengthen the cable, that might be allowing noise interference, ESPECIALLY if the extender isn't shielded.
Reply to NavySEALBrian
Sorry I couldn't respond earlier. And thanks for your reply.
I'm not using any extender. My mobo's audio is HD, so I connected the HD connector. and I'm sure about it.
------------------------------ Antec 902--ASUS P5KSE, thermaltake extreme spirit II--FSP 500w--E6750 @ 3.6 Ghz, Zalman CNPS 9500--OCZ reaper HPC 4 Gb @ 1081 mhz--GF 8800GT @ 700,1700,920, Zalman alcu700--WD caviar Green 1TB--Maxtor 160 Gb--BenQ T2200 HD--Benq FP72E--7RC ultimate 64bit
Reply to avatar_raq
I have the same problem w/my antec 300 and the headphone out port.
Reply to sparky13
@Sparky
What mobo and how do you route the cable of FP audio?
Reply to avatar_raq
There are 570 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
