Tom's Hardware > Forum > Motherboards & Memory > Memory > Problems With CPU-Z?
Forum Motherboards & Memory : Memory - Problems With CPU-Z?
Ok so here is the deal...
Last night I took my whole rig apart, cleaned, dusted, re-pasted CPU and put everything back together....
Then when I booted to Bios and started to change the Ram timings and Cpu settings, for some odd reason when I booted to windows and pulled up CPU-Z this is what came up :
[img]http://i683.photobucket.com/albums/vv199/OvrClkr/DSC00915.jpg[/img]
But before I did all this to the comp, under the RAM speed it stated that the Ram Speed "Frequency" was at 406Mhz and not 203Mhz....
My question is, does CPU-Z have a glitch? cause in my BIOS I have it as the following :
Timings : 5-5-5-15-24-2T
Frequency : changed from 233Mhz to 400Mhz : 800Mhz (DDR2)
Voltage : 1.9v
FSB :@ 203 for now....
Mult @ x17
Vcore @ 1.325
HT @ 2000MHZ
HT voltage @ 1.325
Did I miss something in the BIOS?
I am at the point that I am willing to pay someone if they can come up with the reason why CPU-Z shows 203Mhz as opposed to 406Mhz..... [:lectrocrew:1]
------------------------------ 550 @ 4.0 Ghz 1.425v
BFG GTX 260 (216)
4GB G.Skill @ 960MHz
Thermaltake TP 850w
Sponsored Links
Yeah, looks like your RAM is set to run the same speed as the FSB. Go into the BIOS and change it to DDR2 800.
------------------------------ Playing X-Men Origins: Wolverine Athlon 64 X2 5000+ @3.24 Brisbane | GIGABYTE GA-MA790X-DS4 | 4GB Mushkin DDR2 1066 | Plextor 760A| 2x 3850 512M CF| WD 1TB Black| Fortron Blue Storm II 500W | APEVIA X-Dreamer Black | Win XP Pro & Vista Buisness 32bit
Reply to megamanx00
Yea, I changed the speed from 233Mhz to 400Mhz but I dont understand why CPU-Z shows 203MHZ and NOT 403MHZ (BIOS says its running at DDR2 800MHZ)
My motherboard gives me the following options :
233 / 333 / 400 and 533 ..............
I have tried everything and I am hoping the RAM is not the ISSUE here....
BFG GTX 260 (216)
Thermaltake TP 850w
Reply to OvrClkr
Is there any other program i can use besides CPU-Z that can give me the correct actual speed?
I have everest ultimate as well but dont know what bench I would have to use to confirm the correct speed....
Any feedback would be greatly appreciated !!!
BFG GTX 260 (216)
Thermaltake TP 850w
Reply to OvrClkr
Use the memory tab in CPUz and not the validation.
Also try: cpu tweaker
http://www.tweakers.fr/cputweaker.html
Reply to flyin15sec
Yea, im going by both the tab and the validation.... and thx for the feedback... for some reason I cleared the CMOS and now its good to go!!! 400MHZ!!!!
BFG GTX 260 (216)
Thermaltake TP 850w
Reply to OvrClkr
Issue resolved, thread now closed.....
BFG GTX 260 (216)
Thermaltake TP 850w
Reply to OvrClkr
There are 1205 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
