Are my parts compatible with my motherboard??
willits479
32
Current Motherboard info (in my pc right now)
Board: ECS 945GZT-M ECS
Bus Clock: 200 megahertz
BIOS: American Megatrends Inc. 080012 04/18/2007
Hopefully this will be good enough for my upgrading...
This is what i think im going to go with if my motherboard can handle it...
Video card: I might need to go a little cheaper though because im on a tight budget.
Newegg.com - EVGA 896-P3-1255-A1 GeForce GTX 260 Core 216 896MB 448-bit GDDR3 PCI Express 2.0 x16 HDCP Ready SLI Supported Video Card - Desktop Graphics / Video Cards
Processor:
Newegg.com - Intel Core 2 Duo E8500 Wolfdale 3.16GHz 6MB L2 Cache LGA 775 65W Dual-Core Processor - Processors - Desktops
or
Newegg.com - Intel Core 2 Duo E8400 Wolfdale 3.0GHz 6MB L2 Cache LGA 775 65W Dual-Core Processor - Processors - Desktops
and probablly a new psu but i have not picked one out yet...
Let me know what you think..thanks again
major53
502
willits479 ( aford10 ) is right theirs no way the ecs 945 will support the E8400 or the E8500,I believe the p35 and up will support the E8400 & E8500.
If you want the E8xx series cpu and the gtx260, you are going to have to upgrade your board, which is also going to require you to upgrade the RAM. You are basically looking at a new build. You could keep the case, hd, and opticals to save some $$. You are looking at ~$500 for those.
If you wanted to cut some off of that, I would recommend the 4850 video card instead.
willits479
32
ok well without having to get a new board what is the best processor and video card i could get with my current motherboard?
It would probably work with a bios flash. The cpu support list is sometimes like the memory support list (incomplete). The board supports that FSB, the e5200 is just clocked faster.
Not saying it WOULD work, just saying I think it might.
Ya, you have one pcie x 16 slot. But, your board and cpu are really going to handicap a good video card. There isn't much point in buying a $200 video card with your setup, unless you are planning an overhaul in the next 5 months or so.
willits479
32
its not good enought someone already told me im gonna need to get a new one...i guess im gonna have to upgrade pretty much everything....will someone start me off with a couple good motherboards that arent too expensive...under 200.
thanks
willits479
32
that looks great thanks...after that i think im gonna go with
EVGA 512-P3-N871-AR GeForce 9800 GTX(G92) 512MB 256-bit GDDR3 PCI Express 2.0 x16 HDCP Ready SLI Supported Video Card - Retail
Intel Core 2 Duo E8500 Wolfdale 3.16GHz LGA 775 65W Dual-Core Processor Model BX80570E8500 - Retail
A-DATA 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) Dual Channel Kit Desktop Memory Model HY63I1B16KN - Retail
if you think there are any problems with these choices please feel free to correct me or show me somthing better.
willits479
32
ok now i have another question...if vista came pre installed on my current computer is there anyway that i can transfer it to a new motherboard?
willits479
32
