Recently replaced the guts of my 939 rig with AM3.
ASUS M4A87TD EVO, Athlon2 X3 445, Corsair CMD4GX3M2B1600C8 Dominator 2 x 2gb 1600, Seasonic SS-600HT 600WPSU, P180, AMD heatsink and fan with artic silver
Been running fine for a few weeks so I had a look at the Asus TurboV Evo software that came with the mobo and tried the auto tuning button. Managed 232 Mhz at 15.5x with one click. I know this is pretty half assed OC'in but thought it was worth a look and is encouraging getting 3.6 GHz from the stock setup.
I had previously tried the core unlock button on the mobo during initial install but it only recognised 3 cores so thought my fourth must have been bad. Decided to try again and now I have an AMD phenom II X4 at 3.6GHz.
This is great news but just wondering if I should be running this at 3.6GHz on the stock AMD fan?
while surfing I am at 35 degC (30degC on sleep mode). Tried using the stability test on the AMD OverDrive software to fire up all 4 cores and it hit 61 degC within only 2 minutes and was still rising so i decided to stop. Playing "world in conflict" (2007 spec RTS game) it is stable at 54 degC.
I am in the process of selling my Scythe Ninja Plus from my 939 rig which seemed to be a big waste of money since I never got round to overclocking that system. Because of this I never bought an aftermarket heatsink for the AM3.
I don't want to damage anything so at the moment I have reverted back to 3.1Ghz at X4 and the stability test temperature stabilises at 58 degC after ten minutes.
So do I need a aftermarket fan? I have 75 degC noted as the max temperature for the CPU but at what temperature should I be aiming to operate at?
The rig is only surfing probably 70% of its life with the rest office applications and medium spec gaming.
