Hi, i have a 8800GT gigabyte graphic card... Off late, my PC after goin into standy wont wake up... this is a very strange issue... after i standby it goes off as usual... after i press the power button ( usually how i wake the system , and it was working all this while ) , the lights go ON, and fan spins and everything... but no display on the monitor.... Plz help me out !
I think it was related with screen refresh, after coming back on the card would default the Frequency settings above the acceptable range for my TV and thus I would not get any picture back on...
That was like 5 - 6 months ago I really dont know what I did, I know that I kept updating the Nvidia drivers and eventually that issue was resolved. It must have been with some of the screen resolution settings in the Nvidia Control Panel.
What kind of display do you have? Make sure that the correct refresh settings are selected in the display properties.
I've fixed this issue.. i just enabled Nview settings in the control panel... and then in power options i set everythin to NEVER... this seems to ve fixed it.
