Tom's Hardware > Forum > Motherboards & Memory > Memory > [Solved] How to get exactly 800MHz from OCZ Blade DDR2 Memory?
Forum Motherboards & Memory : Memory - [Solved] How to get exactly 800MHz from OCZ Blade DDR2 Memory?
Best answer from ubernoobie.
I have recently built my new gaming rig and have got some very good parts in it for the money I spent on it.
That being said, I am having some trouble getting the actual 800MHz from my DDR2 OCZ Blade (2x2GB) RAM. I have set the DRAM Frequency to DDR2-800MHz, the timings to 4-4-4-15 like they are suppose to be with a voltage of 2.1.
All this and it is still running at 400.8 MHz according to CPU-Z.
So here's my basic comp makeup:
ASUS P5Q Pro Mobo
Intel Quad Core Q9550 @ 2.838GHz
OCZ Blade DDR2-6400 (2x2GB @ 800MHz)
HIS HD 4850 ICEQ4 Turbo 512 Mb
Any ideas on how to get my exact RAM frequency would be appreciated.
cpu-z is showing the memory correctly, 400mhz x 2 = 800mhz as ddr2 is double pumped
Sponsored Links
Best answer
Reply to ubernoobie
Working just like it should...too bad you don't understand...
Reply to marcellis22
Quote :
Yeah, thanks for that info. I forgot that these are 2T.
Quote :
It's people like you that I sit and laugh at for wanting to be a jerk when you can't explain it yourself. (Or maybe just to lazy)
Thanks again ubernoobie.
Reply to redneckemperor
There are 1246 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
