Will a cpu requiring 12 volt (AMD Athlon) not boot up on 10 volt? I think I have a faulty PSU. Only 10 volts at cpu.
Sponsored Links
The system should not even complete the POST.
So, how do you know it's 10 volts? If you voltage sensor says 10 volts, you can double check by using a dmm and measuring between the yellow and black wires on one of the molex connectors.
Reply to jsc
That sounds like a bad powersupply to me, still a good idea to check with a volt meter as jsc suggests if that isn't the source of your information as it is. If you need a new supply, get a good quality brand like PC Power and Cooling and that should cut down on the power supply related issues.
------------------------------ Athlon 64 X2 4400+ @2.4GHZ,Zalman CNP9500 LED CPU cooler Asus A8N32-SLI Deluxe, 2GB Corsair XMS-3500LL w/ activity lights, Nvidia 9800GTX 512MB, 2 x 400Gb Western Digital Sata drives, Audigy 2 Zs, PC Power and Cooling Turbo Cool 1Kw
Reply to HVdynamo
- 0 +
What kinda PSU do you have now?
Reply to AKM880
- 0 +
I checked voltage w/ a multimeter. The PSU is an Enermax Noisetaker 2
Reply to mj3437
Time to go shopping mate.
Reply to mousemonkey
- 0 +
That's what I figured. I'm looking at the Ultra x3 600 watt modular.
Reply to mj3437
I wouldn't if it were my money.
http://enthusiast.hardocp.com/article.html?art=MTQzNyw0LCwxNTA=
- 0 +
Something like a Corsair, or Antec would a good PSU brand. I don't really like Ultra PSUs all that much.
Reply to AKM880
Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > Power supply question
There are 1037 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
