After using ATI Overdrive, GPU stuck at 400mhz
Related ressources
- ATI Overdrive UNDERclocks 2D! - Forum
- Problems using 2nd monitor after using ATI CCC Overdrive - Forum
- ATI Radeon 5770 GPU /MEM clocks stuck at 400/900... - Forum
- 5850 stuck at 400MHz - Forum
- Random insert pixels after auto overdrive 2x5770 crossfire + 5470 - Forum
Related ressources:
- ForumATI Overdrive Issue
- ForumATi Overdrive Tab missing after driver update - How to bri..
- ForumHelp, system randomly crashes after installing new 7870
- ForumATI 5970 Overdrive disaster please help
- ForumMy 2nd monitor (CRT) is flickering due to entering ATI overdrive .
- ForumTwin Frozr II Ati overdrive Blocked?
- ForumAti overdrive
- ForumDisable ATI Overdrive ?
- ForumATI Overdrive question
- ForumI5 3570K + Z77 PRO3
- Forum[Solved] I am using an air conditioner to cool the hardware inside the cabinet.
- ForumNo video after running ntune
- Forum[Solved] Does ATI Overdrive void your warranty?
- ForumDisable ATI Overdrive?
- Forum[Solved] Green artifacting after AMD 435 X3 unlock
- More resources
Read discussions in other Overclocking categories
Except that even with that said, makes me think I should get the 5970 instead ... is it worth the extra ~$150?
