Ok, i actually will have a 22" monitor with a max resolution of 1680 x 1050. will the 8800 gt still be sufficent or should i upgrade my card then.
i would like to play fallout3 and cod4 in the highest possible resolution if i can. or go sli perhaps. does it have to be in that case the exact same card?
I have a 8800GTS (G92) which is pretty much like the 8800GT and it plays Fallout 3 well. It could be better, but very playable overall. Save you money for now and wait for the next generation of cards if you want to have a very significant upgrade.
------------------------------The capacity to learn is a gift; The ability to learn is a skill; The willingness to learn is a choice. - Rebec of Ginaz
Reply to Zenthar
