Hey guys,
I'm in the process of building a new computer, using an amd phenom ii x6 1055t
My hopes for this computer would be to serve as my main computer, but also be very portable seeing as I attend lan events frequently.
I'm building in The NZXT Vulcan case, which is micro ATX but supports heat sinks up to 165mm tall. However, I'm still trying to keep some space open so I can mount a 200mm fan on the side of the case.
My main concern is that most modern heat sinks built for these high performance CPU's weigh in at 800grams + And I would like to know what size heat sink i could safely carry around in a lan case without a large risk of damage to the motherboard or cpu.
Just for relevancy, here are links to the case and mobo:
[Case] http://www.newegg.com/Product/Product.aspx?Item=N82E16811146065
[Mobo] http://www.newegg.com/Product/Product.aspx?Item=N82E16813130293
Thanks for any replies!
