Tom's Hardware > Forum > Motherboards & Memory > Memory > Memory speed for overclocking E5200
I am thinking about building a system based on the E5200 and over clocking. Is it recommended to use DDR2 800 or DDR2 1066 for this task. Thanks in advance.
Respectfully
John
Sponsored Links
Which motherboard are you thinking of?
Reply to Nils
MSI P43 Neo-F which supports changing the FSB with jumpers on the MB as well as traditional BIOS OC options.
Reply to ex_soldier1911
Well, you should try to find some articles which compare 800mhz vs. 1066mhz. The general though however is: lower timings is better than higher speeds. It's all up to you and your budget. If can only afford DDR2 1066 with high timings it's better to buy DDR2 800 with very low timings. However if you can afford ddr2 1066 with the lowest timings, which shouldn't be a problem as ddr2 prices are low, go for it.
The only reason I can see why some would prefer 800mhz over 1066mhz, is because it is easier to run at a DRAM:FSB ratio of 1:1 with ddr2 800 than with 1066. This is mostly considered as the most stable configuration, but you shouldn't care too much about it as it is seriously overdone.
Reply to Nils
There are 739 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
