Hello, My Win 7 keeps pixelating and dropping out randomly.
A message has been received that there is a solution to the problem, but unfortunatley I when I click on the link it does not take me to it. Says Problem with Nvidia Graphics driver.
You may have issues with your card. Pixelating often occurs when the GPU memory is failing. I just learnt that in some cases this can be due to solder cracking on the card. Apparently you can "bake" the card in a manner that remelts the solder. Apparently the process known as GPU Baking can be found on Google. This is of course is assuming the card is the problem at a hardware level for that reason. Make sure your PSU is putting out good stable voltage as this can affect GPU behaviour.
