Tom's Hardware > Forum > Graphic & Displays > ATI > HDMI graphics card caused sound drivers to not work right
Forum Graphic & Displays : ATI - HDMI graphics card caused sound drivers to not work right
I recently purchased a ATI radeon 4840 HD graphics card. i am running the screen on the HDMI port and i get sound through my tv, but all the old jacks in the computer no longer owrk... i cant connect any mics or additional speakers. i made sure to update the graphics card and try rweinstallling the drivers for the jacks on my computer. but it seems the graphics card is keeping the jacks from working. the drivers are installed and there. but when i go under sound options it only shows the hdmi sound and says no audio recording devices are installed.... any way to make them owrk again??
Sponsored Links
It's a honest mistkae :) When HDMI sound is enabled other output ports from soundcard aredisabled.
If you want to use other speakers you have to rewire them through the TV's output ports.
Cheers
Reply to Euphoria_MK
- 0 +
what about a mic? the input jack for that isnt working either
Reply to wtdz90
Hmm, mic should be working... Go into control panel sound devices, and you can select there Mic and configure the properties for the mic.
I am not sure, but is working on my side. I'll try it out again when I get home later tonight....
HDCP disables analog ports. you can blame cablelabs and the national association of broadcasters for the issue.
Reply to Ignatowski
- 0 +
Check in Device Manager, ATI cards install their own sound system drivers which can block other sound cards from working. Locate the ATI sound device and disable it.
Reply to coozie7
There are 1050 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
