Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > GTX-285 Power supply requirements
Hello ppl :)
I was about to purchase a GTX 285 in the near future, but i do have a few things in mind, so if you'd be so kind as to help me....
1- My Current Powersupply is Cooler Master eXtreme Power 600W. It supplies 18A on the 12 v rail. If i go sli in the future, will i need to change powersupply ? If so, will anything less than 1k watts work or is that a must?
1A- Are tehre any links showing the power consumed by these cards?
2- I have two offers atm, one is the XFX GTx285 and an EVGA GTx285 (Both with standard clocks), so any suggestions regarding either? THe evga is arnd 22$ lesser.... Also note that my mobo is XFX 750i.
Thnx in advance :D
Sponsored Links
1. No that PSU will not be able to handle 2 285...
And you wont need a 1KW PSU...The 750W from PC&P/corsair(Preferred) or from any gud manufacturers should do...
2. Well here is a PSU calculator, which will give you a rough idea about how much watts your setup will consume...they mostly give a higher value but you get an idea...
http://extreme.outervision.com/psucalculatorlite.jsp
2. Get the EVGA...
Message edited by gkay09 on 03-23-2009 at 09:32:10 AM
Reply to gkay09
Usually you will see people get single railing, which can be "OK" but, if your going to get some top stuff/oc'ing/multitask mainly, look at split railing like 4+ rails of 18/20a+. That might look low to you but, in actuality, 18a's is alot but, not 2 12v rails on 600w of 18a for the whole computer.
GTX 285 - 750w corsair/ocz/pc power cooling - mainly high end gamers that like to kill there electricity get single railing or like to think they can get a much better oc with single rail. If you decide to sli later on, look in the 850w+ range.
Message quoted 1 times
Message edited by fullmetall on 03-23-2009 at 02:49:29 PM
Reply to fullmetall
Is your system still the same as the one in your profile? If so the GTX285 is complete overkill.
A good quality 600W+ PSU could handle 2 GTX285.
------------------------------ *How To Ask For New Build Advice*
HAF 922 | HX750
Rampage2Gene | i7 920 D0 | 6GB Gold 1600 | Hyper 212+
Caviar Black 640GB | HD3870
Reply to theAnimal
- 0 +
Hmm, firstly, thanx to all who replied :)
@gkay09: Thanx for the psu calculator link :) Been trying to find something like that for quite some time now :D
@Fullmetall: I plan to sli later , as in about after a year or so... till then i hope the psu prices wud also come down,.. til then ill have my trusty ol 600w with me with the 285 :D
@theAnimal: yep, im using this rig atm, but im getting another one just now, and ill swith the 600w psu to the new rig, and get a 400w for this one. Actually, im already over my budget, hence the swap. Im currently getting the following System:
Q6600
XFX 750i Sli mobo
2x Corsair XMS2 DDR800 2GB rams
And prolly an EVGA GTX285 (or maybe an xfx one.. havent decded yet, tho the xfx is more tempting than evga :( )
Will use the 600w with the gtx285, and get a new temp 400w one with the 7900GT.
As for the q6600, i know its getting obsolete, but i will oc, and think itll perform better than the q9400, which is over my budget.
Same with the 750i, cant spend more.. and i dont like intel chipsets :(
But recommendations are always welcome :D
Message edited by c0d3r on 03-23-2009 at 04:52:56 PM
Reply to c0d3r
Are you getting a new monitor as well? A 9800GT is more than enough for a 17".
HAF 922 | HX750
Reply to theAnimal
- 0 +
Oh yeah, that too... im going for Viewsonic 20" va2102wb.... Res: 1680 x 1050
Coz 285 min res for best performance is 1600x1200 ii think. And 1280x1024 wud be a disgrace to such a card :)
Reply to c0d3r
Is that this monitor??
http://www.newegg.com/Product/Prod [...] ic%2020%22
for the price, you could be getting a 24"
http://www.newegg.com/Product/Prod [...] 6824009125
or more likely a 22"
http://www.newegg.com/Product/Prod [...] 6824001268
21.5"
http://www.newegg.com/Product/Prod [...] 6824236051
Message edited by fullmetall on 03-23-2009 at 09:28:20 PM
Reply to fullmetall
- 0 +
I am running a gtx285 with a corsair 550 just fine.
Reply to caniba
I wouldn't get a GTX285 or bother with SLI for anything less than 1920x1080/1200.
I know you said you don't like Intel chipsets, but they are far better than nVidia chipsets.
Q8300 and Q9300 are both faster than Q6600. Your other option would be a Phenom II X4 940 and AMD based mobo.
HAF 922 | HX750
Reply to theAnimal
- 0 +
nope, its actually this one:
http://www.viewsoniceurope.com/data/60/VA2010wb.pdf
There is another Viewsonic 22"in the same price, same res, but i dont like its looks :/
As for teh q8300 or q9300, they go over my budget, and besides, at 3.0g and a lil above, the q6600 shud beat em :) Phenoms arnt that future proof as the intel now a days imho :(
And as for chipsets, please suggest me intel chipsets comparative to nvidia's. Coz the G31 has got bad reviews, and so has P45 / G45.. i dont have the money to go for the X series :(
Reply to c0d3r
P45 Gigabyte UD3R and the UD3P is probably the most stable p45 out there, i dont get where your seeing its bad...
Same as the Asus P5Q and the Asus P5Q PRO,
Those are the most recommended buy in the intel side for ati. and the single slots can be used for any single gpu ati/nvidia.
as for the 22" Look at the Samsung 21.5 - 22" and Dell also has good monitors.
Reply to fullmetall
Q8X00 and Q9X00 are faster clock for clock than the Q6600.
HAF 922 | HX750
Reply to theAnimal
- 0 +
May I make a suggestion?
At the resoloution given, a GTX260 would be a better bet than a GTX285, and you could put the money saved into a better PSU.
Reply to coozie7
- 0 +
Ok, so re arranging the topic:
1- I have two offers atm, one is the XFX GTx285 and an EVGA GTx285 (Both with standard clocks), so any suggestions regarding either? THe evga is arnd 22$ lesser.... Also note that my mobo is XFX 750i.
XFX Card: http://www.xfxforce.com/en-us/Prod [...] delID=3538
EVGA Card: http://www.evga.com/products/moreI [...] s%20Family
2- Since the cpu question is arisen, ill look into it again... tho any decisiv links would really help :D
@coozie7: Actually, i dont plan to spend this much on a pc till arnd three more years after this, so its basically future proofing with gtx285. As for psu, ill see if i can get a 850w one :(
Message edited by c0d3r on 03-27-2009 at 03:34:33 AM
Reply to c0d3r
- 0 +
they both great with great warranties. Get whichever is cheaper. I you don't plan on going sli get the corsair 650 psu, if you do get the corsair 850.
Reply to caniba
You can pick up a pc power and cooling 750 quad for the same price or less than the corsair. The pc&c is one of the best if not the best power supplies out there. The 750 quad peaks at 860 watts. It has plenty of power to run sli and maybe tri sli 285's.
Reply to chef7734
- 0 +
Well here is another tough one: What should i go for from these mobo's:
XFX 750i SLI
ASUS P5QE
Asus P5Q Pro
MSI P54 Neo3
SLI might be an option, but its farr off, and almost negligible. Stability and OCing are important.
Reply to c0d3r
- 0 +
Asus P5Q Pro or my preference for P45 the gigabyte UD3R or P
Reply to caniba
- 0 +
oh as for the psu, ive already got a Collermaster 600w, so ill use that for the 285. As for the 7900gt that i currently have, guess ill buy a 450w psu :/
Reply to c0d3r
Just to let you know, if you decide to upgrade again to sli, make sure you get a psu 850w +
Reply to fullmetall
I have this system: Cpu: I 720 Oc 3.6 Gb, MB Msi Platinum X58, SuperTalent DDR3-1600 6GB,.....a PSU : Thermaltake Toughpower 600W, with 4 rail of 18 A, end two six-pin PCI Express power connectors.
I want to buy the GTX 285 BFG OC2 video card, or a Evga SC gtx 285.
Please help me if you know, Wat is the thing with rails( PSU has a total 48 A, how this is calculated??? )end If a GTX 285 with a necessary of 40A/42A it wil work with my power supply.I don't have money for another PSU !
Thank you
Message edited by dominatorix on 05-02-2009 at 06:57:08 PM
Reply to dominatorix
- 0 +
Wow man!
A GTX 285 on a 550W ?
So My Xigmatek 750W should be good A ?
I had put a 550W Rosewill in an old P4 HT Extreme AGP 8X 7800GS, Worked good.
Wow He's Right!
That Site says my Rig only needs a 422W PSU!
I changed it to a GTX 295 and still only needed a 522W!
Thanks for the Link!
Good Post Guys.
Awesome!
Message edited by Zerk on 05-14-2009 at 05:08:43 AM
------------------------------ http://i294.photobucket.com/albums/mm100/Dundun_2008/nvidia.gif
http://valid.canardpc.com/cache/banner/496512.png
Reply to Zerk
I'll support what everyone else is saying and agree that 600W will be good for a single 285, I'm only using a 700W. However, if you ever intend on SLI, you'll have to go 850+ to run more than one 285. As far as the Q6600 goes, I say go for it. I bought mine a few months ago and couldn't be happier. OCing it at 3Ghz with no problems at all, on a 750i FTW mobo.
Reply to killerzuchini
- 0 +
Sorry for being away and not replying... i finally got me system, specs are as follows:
Q9400
MSI P43 neo
2x2GB Comsair XMS2
EVGA GTX285 1GB
Coolermaster 600W
Coolermaster Elite 334 casing
Samsung Syncmaster 22" (1680x1050 res)
As for the psu, i ran the 285 on a 500W powersupply aswell (Coolermaster 500w), and it ran fine on the above res. However, the system was a 3800+x2, 2x1GB Kingston, K8nNeo4 mobo..
Reply to c0d3r
- 0 +
Nice Man!
Hope your happy!
Best of luck!
Reply to Zerk
- 0 +
Hell yeah :D FPS skyrocket!
Reply to c0d3r
There are 1334 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 20:19 israil won the Sophmore badge
  • 01:00 Ishaan won the Uniformed badge
  • 01:00 nofun won the Uniformed badge
  • 01:00 ElMoIsEviL won the Spy badge
  • 01:00 mparham won the Freshman badge
  • 01:00 ishaan won the Freshman badge
  • 01:00 Mario097 won the Uniformed badge
  • 01:00 timobkg won the Freshman badge
  • 01:00 ethr won the Freshman badge
  • 01:00 amirp won the Freshman badge
