I just bought a new motherboard (old HP kept crashing pc), asus m3n78-vm.
The old mobo had support for the 9 pin header for the front panel.
http://img.hexus.net/v2/motherboards/amd/EPoX/8KDA3+/Pins.jpg
This mobo only has support for the 20-8 pin panel.
http://www.starlino.com/data/remote_pc_switch/images/front_panel_connector.gif
It runs fine when i jump the power+ground. Any way i can connect the 9pin (i think its 2 wires, 4 + 5 pins) with the current (old?) slots on my motherboard.
Thanks.
Thanks.
