Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > Best ATI Graphics Solution for $200 or less
Forum Graphic & Displays : Graphics Cards - Best ATI Graphics Solution for $200 or less
I recently built myself the following computer.....
19" 1440x900 Monitor
AMD PII 940 3.0GHz
4GB DDR2 1066 Memory
AMD 790GX Mobo w/ ATI Integrated HD3300 Video Card
I installed crysis to see how it would run and it barely ran on low settings so ive decided thats just not good enough for me, so i ask.....what is the best ATI graphics solution for $200 or less?????
Let me know what you guys think, it can be 1 card or 2 cards crossfire, doesnt matter to me....i just want to get the best performance out of $200 that i can
thanks
Message edited by lasoski311 on 03-23-2009 at 08:56:40 PM
Sponsored Links
Gigabyte hd 4870 1GB for $169 or HIS HD4870 1gb for $179 at newegg
Reply to Euphoria_MK
I agree, HD4870 1GB or 512MB, or HD4850 1GB or 512MB. Possibly even a GTX 260 core 216, but the Radeon cards are better. You would really only need the 1GB if you are doing a lot of gaming with AA, AF and at 1920x1200 or better. A 4870 512MB would be great.
------------------------------ System 1
PDC E5200|OCZ 4GB DDR2 800MHz|WD 640GB SATA |Seagate 160GB SATA
|Sapphire Radeon HD 4850 512MB|Corsair 650W PSU|GA-EP45-UD3R
Reply to sprucebr1
Depends on your plans, 1440x900 is quite a small resoloution, if you intend to purchase a larger monitor, get the 1Gb HD4870, if not then go for the 512 Mb version and save a few (insert local currency here). Its getting hard to recommend the 4850, even at such a low resoloution, given the fairly small price difference between it and the faster HD4870.
Reply to coozie7
The HD 4870 is definitely your price point. Fantastic card for the price. Personally I would go with http://www.zipzoomfly.com/jsp/Prod [...] e=10010168 as XFX offers a fantastic warranty and support.
Reply to Jaysin
There are 1308 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
